Hi there!
I will try to summarize as much as possible the problem I have. I am developing an application to simulate some LoRaWAN devices, and I need to comunicate them to the TTN platform, using the TTN stack with dockers. Even though both the “stat” and the “join-accept” procedures seems to be all right (the second one thanks to you guys), when I try the “uplink”, a mistake is given from the gateway (I am using the Semtech UDP Packet Forwarder communication). Moreover, the documentation followed in the one regarded to the LoRaWAN v1.0.3.
Let’s see the mistake on the gateway side:
It might be not very relevant, but it is also included a picture of the device side:
In case it may help, I am including the JSON returned by that error:
error.json (1013 Bytes)
More clues:
In order to corroborate that the “join-accept” is working well (or that is what it seems), it can be checked by the print done in my program:
devAddr -> B4634D01
nwkSKey -> 1910482B5841434E6A4FEF4D8999741A
appSKey -> 5E968317B4A01D19C80CDBA349F0732A
By this, has anyone had this kind of mistake? If true, what could it be and how it can be solved? If not, what is the best way to find out what is going on?
Thanks beforehand, looking forward to hearing from you soon.
Kind regards.
Daniel.
