TTN Mapper - Decoder
Not sure where I am going wrong here… My decoder outputs the following -
But no results are ever shown.
Not sure when I am going wrong? Integration is all setup etc.
Any help much appreciated!
Honestly, I was never able to integrate TTNMapper. I use the app together with a node (so, if you find a solution, I will be glad to hear :slight_smile: )
App on my Android stopped working correctly after a recent update. Never seems to populate the Gateway count anymore (packets are received though). Maybe a GPS error?
Be great if someone help with some diagnostics with the TTN Mapper integration. As far as I can see my decoder spits out all the required fields for this?
Mmm… I just had a flash of inspiration. I have set the experiment name: likely this will make data not to appear on the main map, but only trhough the experiments page (where I found a lot of points under my experiment name…). So, if you set the experiment name, delete it. I will check as soon as I am back to my car (where I have the tracker).
Will give this a go!! Makes sense!
look in the experiments page, you may find yours and see if data are received;
That was the issue all along! Can see my data on there! Taken the experiment name off now. Thanks!
Thank you for having pushed me in understanding why I was not seeing data with integration :slight_smile:
mmm… for me today no data coming through integration.
Working here after taking out the Experiment name. Our new Gateways have appeared on the ttn mapper map!
Today also my data appeared, yesterday no. Glad to map without having the iPhone always with the app on :slight_smile:
A post was split to a new topic: TTN Mapper offline
