Hello
Doesn’t TTN mapper work anymore?
I can not open the website.
TTN Mapper was offline yesterday for the whole day. This was due to migrating it to a more stable VM. Unfortunately this took longer that anticipated due to the size of the dataset that needed to be copied across.
The system should however be running fine again.
You can also check the #ttn-mapper slack channel on the TTN Slack. Things like these are normally announced there.
Good to know that there is a Slack channel.
I cecked the Twitter account an searched for any other source for the “Service Status” of ttnmapper.org and did not find anything usefull.
Good point. We should use the Twitter account more often.
