I assume the external antenna of an LPS8 is meant to be for LORA. But, I can’t find any confirming information. There is nothing in the manual and even google doesn’t have a picture of the gateways backside. Can anyone confirm, that there is an SMA connector for an external Lora antenna?
It’s a standard sma connector so you can add extension cable and/or alternate antenna. One problem with supplied aerial is it is a 90deg fixed so could limit positioning/placement for some. Just be careful with choice of connector m/f, std vs rp etc.
There is an internal antenna: the WIFI-antenna. The antenna for LoRaWan is connected by the SMA-connector. I measured the small white external antenna with a VNA: it seems to be usable between 860MHz and 920MHz.
The one it ships with is fine as if you get a ‘better’ higher gain antenna you will need to dial back the tx PWR to stay within regs… unless by external you mean one to be placed outdoors in harsher environment on a feeder cable…then the higher gain of new ant can be used to offset the cable and connector losses? My test LPS8 has run fine for 5-6 months with only occasional outages triggered by changes to/loss of WiFi connection ( I moved from wired to wireless enet after few weeks at test site). I’m told latest firmware corrects for poor recovery after WiFi loss, though haven’t had chance to test myself yet as unit is remote and am in lockdown/site not yet accessible even though close by My impression is good value for money with flexible connection options so go for it and let us all know how you get on/your experience…
Thanks Jeff, I just ordered one and will evaluate the indoor antenna performance before I try out an outdoor one (indeed my question referred to mounting one externally).
Good observation that the higher gain would well offset the cable losses.
Once I get everything up and running I will post a report.
Hey Lou,
Did you ever try out an external antenna?
I also have an LPS8 and am considering adding an additional antenna, I’d need to run about 5 metres of cable from where the LPS8 is located to get an antenna up on the roof on a ~2 metre elevation above the roof line. I’m at 260 metres, though in a very hilly area, but I think getting the antenna out of the building would help a little.
actually I haven’t added an external antenna as the one it comes with seems to work fine.
It probably helps that it’s close to a window on the second floor.
I use the LPS8 with an external antenna on the roof. Getting the antenna out of the building will not only help a little bit, it can improve coverage significantly.
The gain of the antenna compensates the loss of the 10m cable.
Depending on the type of cable used. Ten meters of RG58 will set you back almost 5dB where something like Aircell 7 will be less then half (2.3dB) and Ecoflex 15 below 1dB for the same length.
I use Aircell 5. If you need a recommendation: If you dont have the tools or the knowledge how to mount the plugs - buy a ready-made cable.
Many “antenna”-problems are caused by wrong mounted plugs or bending of the cable.
Thanks for sharing! I’d like to extend an LPS8 above a metal roof, but I’m in Canada on 915MHz frequency and it looks like Horizon only supply 868. Anybody have thoughts on a solution for 915MHz?
I have a question for you. Do you have measured the coverage range of this gateway in an urban environment, either with the internal antenna and the external antenna?
I am looking for buying this gateway.
