I’m in the process of setting up a TTN Gateway. The hardware is installed (IMST Light Gateway) and it seems that software works right.
Only the registration process of the gateway fails. On the internet gateway registration page I got the message:
Could not register gateway a gateway with id eui-b827ebfffeb836ac already exists
I’m a little bit confused. In my opinion the EUI is built of the mac address and I have a new gateway. Possibly the manufacture IMST has used this gateway for TTN test before.
Is it possible to release the blocked EUI or what can I do to register my gateway?
Currently, I’m using the default packet forwarder and not the TTN one. I have tried the TTN one but the current binary from the git repository terminates with console message “Illegal instruction”
There’s only one reference to the EUI right now. The timestamp, in UTC, indicates that the gateway was seen seconds ago. If the coordinates indicate this is the very gateway you’re using, then I’d assume there’s currently only one gateway actively using that EUI.
According to the documentation you’re out of luck, but maybe someone from the core team will jump in to help:
This means someone else already registered this Gateway ID or EUI. If you registered to use TTN Packet Forwarder, simply think of a new ID. If you registered to use the UDP Packet Forwarder, check the manual of your gateway to see if you can configure it with a different (random) EUI.
The database did not record you as a collaborator to that gateway. I’ve fixed that now.
Normally you should be able to see the gateway show up in your console now.
I have a similar problem. I’ve registered a gateway eui-0000024b08030010 and by mistake delete it.
Whem I try to register again I get a pop-up “eui already exists”.
I can see my eui in the gateway list but I do not know how to get it out there…
i have the same problem here.
I had a lot of issues with my account, so i deleted my accound.
When i register my gateway now, there is the problem with the following information:
“a gateway with id eui-b827ebfffe870380 already exists”.
Thank you for your help borroz.
I can’t keep going on my work, just because of my problem with the gateway eui id and new account… and now it’s weekend and i would have a lot of time for it, but without gateway i can’t keep working on my project.
Is there someone who can delete my gateway out of the old account?
Though quite commonly used indeed, there is no longer an officially supported way to convert an 48 bits MAC-address into an official EUI64. Also, the new MAC-address could already be in use, or belong to a future gateway, especially when based on the same hardware and when only making minor changes to the unique factory MAC-address.
While the chances for collisions within TTN might be very low, it might also be easier to use an officially supported random EUI64 instead, and change the gateway’s code (or configuration?) to use that value.
So the lesson we can learn is : before you delete your TTN account and start a new one , first delete all devices and gateways, because afterwards it’s, without TTN editing in a database, impossible to use these again ??
