Can't register Gateway - EUI is still in use
Thank you for the lesson, borroz.
But that was my problem and why i deleted my account.
I had a few applications, which i could not delete and i deleted my gateway before i delete my account. :sweat:
uhhhhhhhhhhhhh … :sunglasses:
so how do you change (spoof) your mac adress in a RPI ?
https://www.raspberrypi.org/forums/viewtopic.php?t=171534
yes I understand your problem… very normal, really hope they can help you soon.
thank you for your help arjanvanb.
Sounds good, but where can i change the configuration of my gateway/the gateway’s code?
I installed the gateway with this tutorial -> http://www.technoblogy.com/show?1XKI
Last time i registered my gateway in the console on ttn it works with this tutorial, but now the problem with the already existing eui-id.
So how can i change now the gateway’s code?
Sorry, i’m a completely newbie and that’s why so much questions…
best regards
So you’re using https://github.com/ttn-zh/ic880a-gateway for which install.sh generates the gateway’s EUI only once, using:
GATEWAY_EUI=$(ip link show $GATEWAY_EUI_NIC | awk '/ether/ {print $2}' | awk -F\: '{print $1$2$3"FFFE"$4$5$6}')
GATEWAY_EUI=${GATEWAY_EUI^^} # toupper
echo "Detected EUI $GATEWAY_EUI from $GATEWAY_EUI_NIC"
…and then when selecting “N” for Do you want to use remote settings file? will write it to the local configuration file, defined in $LOCAL_CONFIG_FILE, using:
echo -e "{\n\t\"gateway_conf\": {\n\t\t\"gateway_ID\": \"$GATEWAY_EUI\",\n\t\t\"servers\": [ { \"server_address\": \"router.eu.thethings.network\", \"serv_port_up\": 1700, \"serv_port_down\": 1700, \"serv_enabled\": true } ],\n\t\t\"ref_latitude\": $GATEWAY_LAT,\n\t\t\"ref_longitude\": $GATEWAY_LON,\n\t\t\"ref_altitude\": $GATEWAY_ALT,\n\t\t\"contact_email\": \"$GATEWAY_EMAIL\",\n\t\t\"description\": \"$GATEWAY_NAME\" \n\t}\n}" >$LOCAL_CONFIG_FILE
The config file is defined as:
# Install LoRaWAN packet forwarder repositories
INSTALL_DIR="/opt/ttn-gateway"
LOCAL_CONFIG_FILE=$INSTALL_DIR/bin/local_conf.json
So, I’d say you can edit /opt/ttn-gateway/bin/local_conf.json to change gateway_ID:
sudo nano /opt/ttn-gateway/bin/local_conf.json
thank you so much, but now i have the problem:
“…no such file or directory”
-> So, I’d say you can edit /opt/ttn-gateway/bin/local_conf.json to change gateway_ID.
Do i have to do it on the gateway/pi per ssh? or put the stick in my notebook and search the file with explorer?
You see, i’m really new in this…
Yes, it’s a file on your gateway’s Pi, so using SSH, and then use an command line editor such as nano /opt/ttn-gateway/bin/local_conf.json, might be easiest. What command do you use to start the gateway? That should be in /opt/ttn-gateway too.
You might need to be root to edit the file: sudo nano /opt/ttn-gateway/bin/local_conf.json.
By the way, to create a random EUI using @terrillmoore’s little tool:
git clone https://github.com/things-nyc/random-eui64.git
cd random-eui64/
make random-eui64
I ignored a warning on a Mac, warning: format specifies type 'size_t' (aka 'unsigned long') but the argument has type 'unsigned int'. Next, run:
./random-eui64
Great! I’m getting closer, thank you so much! :slight_smile:
“make random-eui64” - this command before i install the complete gateway with the tutorial from gonzalo/ttn-zh or after everything is ready?
The tool to generate random EUIs is only needed before you edit the config file. Running it will give you a new EUI every time you need one, from which you remove the dashes and then copy it into the configuration file.
./random-eui64
D6-B6-80-D1-D5-1B-E3-1D
…or to remove the dashes on the fly, use ./random-eui64 | tr -d '-':
36D06C66546116EE
56C14B98C630E178
123E454624E1B7C1
3A04F9A32A0B532F
I am not using the above EUIs myself :wink:
arjanvanb - thank you so much!
i’ve found the problem.
now its working!
thank you so much!
the problem was, when i tried to change the local_conf.json file, i was still as ttn registered, then i disconnect the connection to the raspberry and logged in as lgw.
then it works with ./random-eui64 and changing the eui in the local_conf.json file.
you made my day! thank you so much!
Thanks @arjanvanb for pointing out the compile warning. I don’t happen to use a Mac very often and I had not tested. It turned out to be a common problem on systems with 64-bit size_t; Ubuntu 64-bit and macOS in particular. It’s a path that is never taken unless read() from /dev/random fails, which isn’t supposed to happen. But it needed fixing, and it’s now fixed. (https://github.com/things-nyc/random-eui64/issues/1).
@arjanvanb @BoRRoZ @gonzalo
Please can someone help me with deleting my gateway out from TTN?
I’m going crazy with it.
It worked with the ./random-eui64 - the help from arjanvanb, but i have a new gateway and the old gave someone. He can’t register the gateway, because the EUI B827EBFFFE870380 is still registered from TTN side.
I had so much issues and problems with my account and deleting of applications, devices and gateway.
When i deleted a device, application or gateway it wasn’t possible and if it was possible, there was still a a counted device.
Sometime i lost my patience and deleted my account.
So that is the problem now, beause somewhere in the TTN or backend of TTN my device with the EUI B827EBFFFE870380 is still registered.
Is there a contact from TTN or support, which can help me with my problem?
Thank you and greets
Albert
I notified the Community Manager about your problem
just to check… how’s the current situation ?
@rish1
Hi BoRRoZ
If this question is for me: Nothing happens til today
I contacted @Rish again just now and asked him about the status of this.
Hi and sorry for coming late to the party!
I purchased the hardware from @albertrgashi and tried to register the gateway with its official MAC.
Thats the reason why he is asking for support deleting the old record, most likely still associated with his delete account.
The gateway b827ebfffe870380 is still registered in the database with its original position:
   "timestamp":"2018-09-01T10:03:01.520929179Z",
   "uplink":"303776",
   "downlink":"164",
   "location":{
      "latitude":47.30533,
      "longitude":9.081753,
      "altitude":610,
      "source":"REGISTRY"
   "platform":"IMST + Rpi",
   "gps":{
      "altitude":610,
      "source":"REGISTRY"
   "time":"1535796181520929179",
   "rx_ok":303776,
   "tx_in":164
Is there any chance to give have access again to this gateway for me @zone11 or its previews owner @albertrgashi ?
Manually generated EUI break my workflow and the hardware would remain unusable for me.
TNX!
Trying to setup an account using legacy (after failed standard method) I’m new to all this, So deleted the old and trying legacy as that’s what I probably have.
I have 000000FFFF000000 and it already registered, a look in the link above through the list and it is there, look like it could be me. has my name from running my script to connect… to get the address.
How do I register if it already sees it and there now is no account?
Or is it something else?
That is not a valid EUI. You are probably using a device without eth0 network and need to adapt the script to generate a EUI based on the correct name. Use the command ‘ip address’ to list the network adapters available and use the one with a valid IP address listed. Search in the script for eth0 and replace it with the name you found.
just been doing that eventually found it and hadcoded one, it’s in C and I’m not a C person. It’s a PiZero so no eth0. Seem silly rather than just having it as a config setting, but guess that’s the program used.
Still seems daft they don’t get removed from TTN.
Anyway it was valid as it’s now in that server list as 000000ffff000000. :wink:
At some point I should figure out this new version as it’s better. But finding how to do it in python of just some make script for a Pi is not easy. I cannot afford a full blown gateway and there are none near me (yet!)
Many Thanks
