Here’s my example
* Copyright (c) 2015 Thomas Telkamp and Matthijs Kooijman
* Permission is hereby granted, free of charge, to anyone
* obtaining a copy of this document and accompanying files,
* to do whatever they want with them without any restriction,
* including, but not limited to, copying, modification and redistribution.
* NO WARRANTY OF ANY KIND IS PROVIDED.
* This example sends a valid LoRaWAN packet with payload "Hello,
* world!", using frequency and encryption settings matching those of
* the The Things Network.
* This uses OTAA (Over-the-air activation), where where a DevEUI and
* application key is configured, which are used in an over-the-air
* activation procedure where a DevAddr and session keys are
* assigned/generated for use with all further communication.
* Note: LoRaWAN per sub-band duty-cycle limitation is enforced (1% in
* g1, 0.1% in g2), but not the TTN fair usage policy (which is probably
* violated by this sketch when left running for longer)!
* To use this sketch, first register your application and device with
* the things network, to set or generate an AppEUI, DevEUI and AppKey.
* Multiple devices can use the same AppEUI, but each device has its own
* DevEUI and AppKey.
* Do not forget to define the radio type correctly in config.h.
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
//These are located in the extras folder of hte Talk2 library https://bitbucket.org/talk2/talk2-library
#include <T2WhisperNode.h>
#include <LowPower.h>
// This sketch is built off of this sketch and library https://github.com/matthijskooijman/arduino-lmic/blob/master/examples/ttn-otaa/ttn-otaa.ino
T2Flash myFlash; //added for Whisper Node
// 0x70.
static const u1_t PROGMEM APPEUI[8]={ FILLMEIN }; //needs to be in lsb (hit the reverse button on TTN console)
static const u1_t PROGMEM DEVEUI[8]={ FILLMEIN }; //needs to in lsb (hit the reverse button on TTN console)
// practice, a key taken from ttnctl can be copied as-is.
// The key shown here is the semtech default key.
static const u1_t PROGMEM APPKEY[16] = { FILLMEIN }; //in msb format
void os_getDevKey (u1_t* buf) { memcpy_P(buf, APPKEY, 16);}
static uint8_t mydata[] = "hi"; //keep short to minimize data!
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 600; //600s = 10 minutes
// Pin mapping for Whisper Node. Make sure to solder J15 and J16 on back of board for the A2, A3 connections
.nss = 10,
.rxtx = LMIC_UNUSED_PIN,
.rst = 7,
.dio = {2, A2, A3},
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
break;
case EV_BEACON_FOUND:
break;
case EV_BEACON_MISSED:
break;
case EV_BEACON_TRACKED:
break;
case EV_JOINING:
break;
case EV_JOINED:
// during join, but not supported by TTN at this time).
LMIC_setLinkCheckMode(0);
break;
case EV_RFU1:
Serial.println(F("EV_RFU1"));
break;
case EV_JOIN_FAILED:
break;
case EV_REJOIN_FAILED:
break;
break;
case EV_TXCOMPLETE:
if (LMIC.dataLen) {
Serial.println(LMIC.dataLen);
// Schedule next transmission
//os_setTimedCallback(&sendjob, os_getTime() + sec2osticks(TX_INTERVAL), do_send);
for (int i=0; i<int(TX_INTERVAL/8); i++) {
// Use library from https://github.com/rocketscream/Low-Power
Serial.println(F("looping"));
Serial.flush();
LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
do_send(&sendjob);
break;
case EV_LOST_TSYNC:
break;
case EV_RESET:
break;
case EV_RXCOMPLETE:
// data received in ping slot
break;
case EV_LINK_DEAD:
break;
case EV_LINK_ALIVE:
break;
default:
break;
void do_send(osjob_t* j){
} else {
void setup() {
Serial.begin(115200);
// Flash - We're not using, so just power it down to save energy
myFlash.init(T2_WPN_FLASH_SPI_CS);
myFlash.powerDown();
// LMIC init
os_init();
LMIC_reset();
LMIC_setLinkCheckMode(0); //turned off again.. i see its also in the EV_JOINED section...
LMIC_setDrTxpow(DR_SF7,14);// this is being ignored.. not sure why
LMIC_selectSubBand(1); //SubBand 1 for US915 TTN
LMIC_setAdrMode(0); // Turn off adaptive data rate
do_send(&sendjob);
void loop() {
os_runloop_once();
