I would like to know why only 3 up link frequency plan for IN865 Band as compare to 8 up link frequency plan for EU868.
Thank You
Dovov
Thank You
Dovov
TTN operates as a subset under LoRaWAN specifications set by the LoRa Alliance, The LoRa Alliance sets specifications and frequency plans under the limits set by the specific regulator for the territory where the plan is defined for…
…therefore this is a question for the regulator in IN
Perhaps worth your lobbying for expansion of allocated frequencies/bands? or perhaps not…
The IRRS is within The Department for Telecommunications in the Minsistry of Communications
https://dot.gov.in/profile
https://dot.gov.in/circulars/indian-radio-regulatory-group-service-rules-2015
