Hi, I have a sistem with 4 nodes and 1 gateway (The things gateway and 4 samd21rf pro nodes), my system have worked for months until this morning when I haven’t received application data anymore.
Today I noticed that Ubidots didn’t received data, so after several checks I see that:
- In Gateways -> Traffic I can see all packets with the correct device IDs
- In application I cannot see packets with the same device ID I have seen in gateway traffic section
What could be the problem?
I already tried to reset frame counters (even if check is disabled, 'cause I’m testing an application)
