Hello guys. I just received ic880a and now I want to configure it. At the moment I would go with this software but as it is almost 3 years old I am sure that there is one better or more updated version?
I would recommend the multi packet forwarder of Jac Kersing.
Do you maybe know any tutorial how to configure it? As I understand I need to configure also TTN connector in order to use TTN?
Also in case you don’t want to go for resin.io (for whatever reason), I have a fork of that repo which runs equally on resin.io or with plain docker.
If you run a docker-compose pull
it will fetch my pre-build containers, so you don’t have to go through the build and can be up and running in minutes.
OK thank you guys. I bought three SD cards so I will try all of this
