Where to change freq to more channels for LMIC MCCI AS923?
I tested my Node with LMIC from MCCI. When I set to AS923 band, the node only hop two freq, 923.2 and 923.4. Where can I modify to use more channels?
Somsak
Somsak,
lorabase_as923.h is the file.Other implementations I’ve seen (e.g.https://github.com/promwungkwa/LMIC-Arduino-AS923-upper/blob/master/src/lmic/lorabase.h ) have 10 channels as per TTN docs (https://www.thethingsnetwork.org/docs/lorawan/frequency-plans.html#as923-925). However the code base is different so you may be better off talking to MCCI about how to make the changes.
Dave
Thank @Dave_Wal. I am also realize the existing of my friend modification in https://github.com/promwungkwa Anyway, I prefer to use MCCI if I can change the code to more Channel.
Somsak
