Good day all,
I configured a node witht he library LMIC. At some point I have to define my application
static const PROGMEM u1_t NWKSKEY[16] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
static const u1_t PROGMEM APPSKEY[16] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
static const u4_t DEVADDR = 0x0000000; // <-- Change this address for every node!
Those variable are u1_t and u4_t.
But what’s u1_t and u4_t?
My nodes works well, but I would like to change a litle bit the way to read those values…
I created my own library and from that library I would like to use those value…
In my file.h,I created some struct
struct Config_radio {
u1_t nwkskey[16];
u1_t appskey[16];
u4_t devaddr;
But when I compile, I got this error message
error: ‘u1_t’ does not name a type
u1_t appskey[16];
Which sound normal, because my LMIC library is not imported in my library file.
I believe those type are created in the LMIC library.
Then I have two question.
How can I create a type (u1_t and u4_t) in my own library?
Or which equivalence can I use.
My goal is when my node is turn on for the first time, it creae a JSON file
"nwkskey": "",
"appskey": "",
"devaddr": ""
My library is going to create that json file with the above lines. The node stop and wait for an action from the user.
The user, remove the SD card, insert the 3 values: When the node is switched on (the seond time), the node is going to read, the values from the json file, and then save it in the EEPROM: The config file is then deleted
Each time the node is switched on, the node is checking for a configuration file. If it exists, it replace the value in the EEPROM. If it does not exist, the node is going to read the EEPROM and if the node does not find a value from the EEPROM, it create and empty json file for the user.
Now my worries is how to use a variable u1_t without having the need to import the LMIC library in my own library.
I wonder if u1_t is like a int.
Can it be int?
int16_t nwkskey[16];
int16_t appskey[16];
int devaddr;
NB: For now, I am working with ABP and I plan to switch to OTAA. But the problem is the same, I will have to read the same type of value for the Application
Thank a lot
