I’m still new to LoRaWAN and trying to understand the join procedure in depth.
In the 1.1 specification the Major is described as follows: “The Major version specifies the format of the messages exchanged in the join procedure (see Chapter 6.2) and the first four bytes of the MAC Payload as described in Chapter 4 […]” (page. 18)
It would appear that the only yet-defined value, R1 corresponds to LoRaWan 1.x
The second part of the passage which you trimmed would make this a bit clearer:
For each major version, end-devices may implement different minor versions of the frame format. The minor version used by an end-device must be made known to the network server beforehand using out of band messages (e.g., as part of the device personalization information).
Eg network servers that support multiple LoRaWan versions ask you to set the version a particular node uses when you register it as LoRaWan 1.02, 1.03 etc. AFAIK TTN doesn’t offer a choice of version, though maybe there’s a change I’m overlooking.
