I would like to build LoRaWAN using Dragino LoRa Shield (for Arduino) and Dragino LoRa / GPS HAT (for Raspberry Pi).
Can anyone tell me how long the communication distance is when LoRaWAN is built?
TROLL alert
I do not know why you say troll.
I am asking because I have confirmed that the LoRaWAN communication between the gateway and the end device using 433MHz frequency does not receive the packet on some obstacles.
Have you actually configured LoRaWAN ?
If your after guidance then you going to need to describe your setup and location in more detail than that.
To answer your original qustion, LoRaWAN can go as far as 835km …
