Nothing - web hooks are cute, but there’s no service delivery guarantee - the TTS CE server shouts it out across the internet and does nothing with the response, if any. I find it very reliable as the whole HTTP / Web thing is well developed after decades of use, but the TTS end has no way of knowing if the message was received.
OK Thanks for that @Nick.
I’ve ruled out a firewall issue by posting curl messages from another server:port
So I’m stuck for any explanation for the app not seeing any uplink traffic.
Is there an example application (pref in nodejs) or an example payload that I can send to help me see what’s happening?
Regards.
OK. I managed to get a dump from TagIO using another webhook. dump of packet from TagoIO.txt (3.1 KB)
The format of one uplink packet is so different that my application can’t parse it.
So I thought of writing a replacement and looked at the documentation here Data Formats | The Things Stack for LoRaWAN
My attached sample has more in it than the doc shows.
It’s also overkill.
Is there a handler on V3 that would give us a much simpler JSON message with just
timestamp, device id and payload?
Regards.
Yes, that certainly helps. However, I was hoping that V2 to V3 migration would not force a rewrite of our entire nodejs application. I deduce that the V2 integration with nodejs has been deprecated and not replaced.
(https://www.thethingsnetwork.org/docs/applications/nodejs/quick-start/ still online)
Regards.
