Any support questions you might have can be asked here:
https://www.thethingsnetwork.org/marketplace/product/vinduino-r3-sensor-station
Hello. I recently purchased the vinduino r3 module and was able to everything up and running. The only issue that I need help with is decoding the payload from ttn and viewing them on cayenne. Appreciate any help. Thanks
@decarli, the std Vinduino station uses a a 7 byte payload: temperature, air rel humidity, battery voltage, soil moisture sensor 1-4. The Cayenne integration for Vinduino expects to see these 7 bytes in this sequence. You can also set up your own Cayenne integration, please refer to the Cayenne on-line documentation for that.
