V3 The Things RAK831 + GPS HAT on a Raspi P3b (time sync issues)
Folks,
I’m running a v3 The Things RAK831 + GPS HAT on a Raspi P3b but in the logs I see a lot of;
07.05.21 14:26:28 (+0200) 2021-05-07 12:26:28.022 [SYN:ERRO] Repeated excessive clock drifts between MCU/SX130X#0 (3 retries): -3.6ppm (threshold 2.4ppm)
07.05.21 14:26:31 (+0200) 2021-05-07 12:26:31.173 [SYN:ERRO] Repeated excessive clock drifts between MCU/SX130X#0 (6 retries): -2.7ppm (threshold 2.4ppm)
07.05.21 14:26:32 (+0200) 2021-05-07 12:26:32.223 [SYN:INFO] Time sync qualities: min=61 q90=79 max=104 (previous q90=100)
07.05.21 14:26:32 (+0200) 2021-05-07 12:26:32.223 [SYN:INFO] MCU/SX130X drift stats: min: -1.4ppm q50: -2.4ppm q80: -3.0ppm max: -5.2ppm - threshold q90: -3.8ppm
07.05.21 14:26:32 (+0200) 2021-05-07 12:26:32.223 [SYN:INFO] Mean MCU drift vs SX130X#0: -2.3ppm
Should I worry?
/rw
Hi
Sorry to hijack your post but do I understand correctly the subject of your message ? You succeeded to connect a RAK831 hat with PI3 with TTS/TTN V3 ?? If so would you mind to share how you did ? :wink:
Thanks a lot in advance,
Vincèn
Hi Vincen, the easiest way to connect to TTN/v3 is to use Balena services.
https://hub.balena.io/marc6/basicstation-gateway-tts
