I try to use “the things uno” to send information to the gateway, like video shows in the ‘quick start’ [https://www.youtube.com/watch?v=rK8oJHZ9Q7U].
But when I registered the device and tried to send a message, the result was like this
-- STATUS
EUI: 0004A30B001C03xx
Battery: 3273
AppEUI: 0000000000000000
DevEUI: 0004A30B001C03xx
Data Rate: 5
RX Delay 1: 1000
RX Delay 2: 2000
-- JOIN
Model: RN2483
Version: 1.0.1
Sending: mac set deveui 0004A30B001C03xx
Sending: mac set adr off
Sending: mac set appeui 0000000000000000
Sending: mac set appkey 77FE7617559F77BA9D82F8F0A603F781
Sending: mac save
Sending: mac set rx2 3 869525000
Sending: mac set ch drrange 1 0 6
Sending: mac set ch dcycle 0 799
Sending: mac set ch dcycle 1 799
Sending: mac set ch dcycle 2 799
Sending: mac set ch dcycle 3 799
Sending: mac set ch freq 3 867100000
Sending: mac set ch drrange 3 0 5
Sending: mac set ch status 3 on
Sending: mac set ch dcycle 4 799
Sending: mac set ch freq 4 867300000
Sending: mac set ch drrange 4 0 5
Sending: mac set ch status 4 on
Sending: mac set ch dcycle 5 799
Sending: mac set ch freq 5 867500000
Sending: mac set ch drrange 5 0 5
Sending: mac set ch status 5 on
Sending: mac set ch dcycle 6 799
Sending: mac set ch freq 6 867700000
Sending: mac set ch drrange 6 0 5
Sending: mac set ch status 6 on
Sending: mac set ch dcycle 7 799
Sending: mac set ch freq 7 867900000
Sending: mac set ch drrange 7 0 5
Sending: mac set ch status 7 on
Sending: mac set pwridx 1
Sending: mac set retx 7
Sending: mac set dr 5
Sending: mac join otaa
Join not accepted: denied
Check your coverage, keys and backend status.
Response is not OK: no_free_ch
Send join command failed
The code I use is
#include <TheThingsNetwork.h>
// Set your AppEUI and AppKey
const char *appEui = "0000000000000000";
const char *appKey = "77FE7617559F77BA9D82F8F0A603F781";
#define loraSerial Serial1
#define debugSerial Serial
// Replace REPLACE_ME with TTN_FP_EU868 or TTN_FP_US915
#define freqPlan TTN_FP_EU868
TheThingsNetwork ttn(loraSerial, debugSerial, freqPlan);
void setup()
loraSerial.begin(57600);
debugSerial.begin(9600);
// Wait a maximum of 10s for Serial Monitor
while (!debugSerial && millis() < 10000)
debugSerial.println("-- STATUS");
ttn.showStatus();
debugSerial.println("-- JOIN");
ttn.join(appEui, appKey);
void loop()
debugSerial.println("-- LOOP");
// Prepare payload of 1 byte to indicate LED status
byte payload[1];
payload[0] = (digitalRead(LED_BUILTIN) == HIGH) ? 1 : 0;
// Send it off
ttn.sendBytes(payload, sizeof(payload));
delay(10000);
The problem seems to be the duty cycle. How can I set it to transmit information successfully?
