Use of LoraWAN in Indonesia
Hi all, I’m trying to implement a LoRaWAN network in Indonesia and I struggle to find good information about the legal use of LoraWAN in Indonesia. The country has very strict rules for any type of telecommunication device. I would greatly appreciate it if someone could help me to finding someone who has a good understanding of the requirements in Indonesia. I tried you get in touch with some of the listed TTN groups but had no luck, so far. This is a commercial project so I’m happy to pay for the advice.
Thank you
IMPORTANT BEFORE POSTING:
Summary
What is the issue you’re facing?
Logs
Please paste any error logs here and use the text format (< / >) option (No screenshots!)
Hardware
What device and/or gateway are you using? Specify vendor, model & version as well.
Try reaching out to the LoRa-Alliance for guidance and assist and if considering using The Things Industries infrastructure or services then @rish1 would be a good start contact for any commercial engagement :slight_smile:
(and even if commercial would be good spirited and community minded if you could also openly peer with TTN (through PacketBroker) to help the local communities :+1: - also good for corporate ESG goals :wink: )
