We have a LoRa demo that we try to use in China (with TTN network). It is made of a LoRa device and a LoRa gateway. Both have been registered on The Things Network.
On the page giving the frequency plan per region (Frequency Plans | The Things Stack for LoRaWAN), we have seen that it indicates to use CN_470_510_FSB_11 rather than CN_470_510_FSB_1
Here are the frequencies for FSB 11: lorawan-frequency-plans/CN_470_510_FSB_11.yml at master · TheThingsNetwork/lorawan-frequency-plans · GitHub
And here are the ones for FSB 1: lorawan-frequency-plans/CN_470_510_FSB_1.yml at master · TheThingsNetwork/lorawan-frequency-plans · GitHub
We currently have an issue which seems related to the choice of this Frequency Sub Band.
For the moment the LoRa device and the LoRa gateway don’t understand eachother.
We have enabled some debugging info and seen that the LoRa device communicates on the following frequencies:
28s813:Channel:82 Frequency = 486700000
53s674:Channel:86 Frequency = 487500000
653s681:Channel:87 Frequency = 487700000
1253s688:Channel:85 Frequency = 487300000
1853s695:Channel:86 Frequency = 487500000
(those frequencies are in FSB 11)
wheras the LoRa gateway accepts frequencies between 471.5 MHz and 472.9 MHz (those frequencies are partly in FSB 1).
I think that the LoRa gateway is configured for FSB 1 whereas the device is trying to communicate on FSB 11.
Can you please give us some advices? Is a LoRa gateway supposed to scan every Frequency Sub Bands (here FSB 1 + FSB 11) or is it normal that it scans only some frequencies?
Here we own the gateway so we can try to change its configuration but how would it work if a LoRa device configured for FSB 11 tries to contact a Gateway configured for FSB 1?
Thank you
