I recently moved to the community stack, and merged my gateway and end nodes. Today I tried an uplink from my RAK811 module (connected to RPi), and successfully received the data on the V2 stack. However, in my application on the V3 stack it says that the join request was dropped due to “uplink channel not found”.
Have anyone had a similar problem after merging to V3?
PS: Sorry in advance if this post lack necessary information or is badly formulated
You can have it setup on both v2 & v3 but if the gateway is on v2, it’s not going to pass on the details to v3 as it gets a match on v2. So you’d need to change one of the keys on v2, at which point the v2 network will forward the uplink to see if v3 can process it.
I have now changed the AppKey in V2, and The Things Community Stack is able to receive the join request. HOWEVER, each join request is dropped, saying the same thing: “Uplink channel not found”
Make sure your frequency plan matches the frequencies used by the device for uplinks. In case of EU868 the device can only use the three default frequencies: 868.1, 868.3 and 868.5 during
OTAA join,
yes, I read about it in the regional parameters document, however I am unsure on how I select these channels for OTAA join. Is this selected in the console, or on my device?
as far as I know, there are no possible way of selecting the join frequency of my device (rak811). It was connecting fine with ttn v2, so I don’t understand why it should not work
TTN V2 accepted join requests using any frequency. TTN V3 tries to be very LoRaWAN specification compliant. The standard specifies the 3 frequencies I mentioned earlier for join requests in EU868 so that is what V3 accepts.
What are the frequencies used by the device when you get those messages?
I am using the V3.0.x firmware on the rak811 module.
I am using the one suggested in the migration tutorial: " MAC V1.0.2, PHY V1.0.2 REV B"
I tried to delete and reregister the end device, however the problem still occurs. It is weird because it seem like the end-node selects all other frequencies than the three used for joining (868.1, 868.3 and 868.5)
I installed rak811v3 on another raspberry device, and after 6-7 join requests it worked. I was able to receive messages from it, however the command line in on the Pi gives me a timeout error.
