Upgrade to TTS CE v3.14.1, Aug 9, 11:30 - 13:30 CEST
During this maintenance window TTI will upgrade TTS CE aka The Things Network v3.14.1
They do not expect noticeable downtime during this deployment.
Here is the changelog since the current version v3.14.0:
Added
  • New config option --as.packages.timeout to control the message processing timeout of application packages.
  • Option to retain current Gateway ID while claiming.
  • Option to view and copy error details in full view errors in the Console.
  • Metrics for CUPS requests.
  • Language chooser in the footer in the Console.
  • Japanese language support in the Console.
  • Metrics for gateway claiming.
  • Option to disable primary email and name update via stack.
Changed
  • Cache Root CA for client TLS configuration.
  • Identity Server no longer allows removing the _ALL right from entity collaborators if that leaves the entity without any collaborator that has the _ALL right.
  • The Network Server application uplink queue may now be skipped if the Application Server peer is available at enqueue time.
  • The interval for updating gateways in Packet Broker is now 10 minutes (was 5 minutes) and the timeout is 5 seconds (was 2 seconds).
Removed
  • Validation of the location field in GatewayAntenna.
Fixed
  • Improved errors when ordering search requests by non-existent fields.
  • LNS authentication key handling for gateways in the Console.
