Completed: Upgrade to The Things Network v3.22.2
This is a cross-post of an incident on our The Things Network status page.
It will be updated automatically.
Scheduled: Mon, 07 Nov 2022 12:00:00 +0100 until 14:30:00 +0100
Resolved: Mon, 07 Nov 2022 14:30:38 +0100
Affected Components
- Europe 1 (eu1.cloud.thethings.network): Operational
- North America 1 (nam1.cloud.thethings.network): Operational
- Australia 1 (au1.cloud.thethings.network): Operational
Scheduled
Posted: Fri, 04 Nov 2022 17:14:26 +0100
During this maintenance window we will upgrade The Things Network v3.22.2
We do not expect noticeable downtime during this deployment.
Here is the changelog since the current version v3.22.1:
Changed
- Class B and C downlinks will no longer be automatically retried indefinitely if none of the gateways are available at the scheduling moment, and the downlink paths come from the last uplink.
- This was already the behavior for downlinks which had their downlink path provided explicitly using the
class_b_c.gateways
field. - The downlinks will be evicted from the downlink queue and a downlink failure event will be generated. The failure event can be observed by the application using the
downlink_failed
message, which is available in all integrations.
- Event history and payload storage TTL has now 1% jitter.
Fixed
- User creation via OpenID Connect now correctly takes into account name clashes with existing organizations.
- Do not require AppKey when skipping Join Server registration in end device onboarding in the Console.
- Fix auto generation of device ID when using DevEUI generator in the Console.
- Fix several device onboarding issues with ABP in the Console.
- Do not ask for a JoinEUI.
- Reinitialize form properly when switching between ABP and OTAA.
- Issue with pasting values into byte input at the wrong position in the Console
In Progress
Posted: Mon, 07 Nov 2022 12:00:41 +0100
Scheduled maintenance is currently in progress. We will provide updates as necessary.
Completed
Posted: Mon, 07 Nov 2022 14:30:38 +0100
The scheduled maintenance has been completed.
