Completed: Upgrade to The Things Network v3.19.0
This is a cross-post of an incident on our The Things Network status page.
It will be updated automatically.
Scheduled: Mon, 18 Apr 2022 12:00:00 +0200 until 13:30:00 +0200
Resolved: Mon, 18 Apr 2022 13:30:23 +0200
Affected Components
- Europe 1 (eu1.cloud.thethings.network): Operational
- North America 1 (nam1.cloud.thethings.network): Operational
- Australia 1 (au1.cloud.thethings.network): Operational
Scheduled
Posted: Fri, 15 Apr 2022 17:29:46 +0200
During this maintenance window we will upgrade The Things Network v3.19.0
We do not expect noticeable downtime during this deployment.
Here is the changelog since the current version 3.18.2:
Added
- Session management page in Account App.
- Status page references in the Console.
- Notification Service API that will allow users to receive notifications about their registered entities.
- This requires a database schema migration (
ttn-lw-stack is-db migrate
) because of the added tables.
- Cluster setting
cluster.cluster-id-address-template
that can be used as a Go template to construct the cluster address from a cluster ID. Example value is{{.}}.thethings.example.com
where{{.}}
gets replaced by the configured cluster ID. - Packet Broker setting
pba.cluster-id-from-address
can be used to construct the Cluster ID from the configured cluster address. This requirescluster.cluster-id-address-template
to be set. - Add
network_server_address
,application_server_address
andjoin_server_address
to applications.- This requires a database schema migration (
) because of the added columns.
- New ADR settings API, which allows stronger control over the ADR algorithm.
- The new settings fields can be found under
mac-settings.adr
, and are mutually exclusive withuse-adr
andadr-margin
. The legacy settings need to be unset before the new API options may be used. mac-settings.adr.mode.disabled
completely disables the ADR algorithm.mac-settings.adr.mode.static.data-rate-index
,mac-settings.adr.mode.static.nb-trans
,mac-settings.adr.mode.static.tx-power-index
allow the user to provide static ADR parameters to be negotiated with the end device. These options persist over multiple sessions and do not require a session reset in order to be propagated to the current session.mac-settings.adr.mode.dynamic.min-data-rate-index
andmac-settings.adr.mode.dynamic.max-data-rate-index
control the data rate index range which the Network Server will attempt to negotiate with the end device. Note that if the provided interval is disjoint with the available data rate indices, no negotiation will take place.mac-settings.adr.mode.dynamic.min-tx-power-index
andmac-settings.adr.mode.dynamic.max-tx-power-index
have similar behavior, but for transmission power indices.mac-settings.adr.mode.dynamic.min-nb-trans
andmac-settings.adr.mode.dynamic.max-nb-trans
have similar behavior, but for NbTrans.mac-settings.adr.mode.dynamic.margin
may be used to provide the margin of the ADR algorithm. It replaces the oldadr-margin
setting.use-adr
andadr-margin
are still supported, but deprecated. Any future API usage should instead use themac-settings.adr
settings.
Changed
- Sortable tables are now sorted by default in the Console
Fixed
- Console determining gateways as "Other cluster" even though using the same host if server addresses not matching exactly (e.g. due to using different host or scheme).
- Inconsistency in setting gateway's LNS Auth key in the Console.
- CLI no longer informs the user that is using the default JoinEUI when passing its value via flags.
- Generating device ID from a DevEUI when importing a CSV file.
- The
is-db migrate
command that failed when running on databases created byv3.18
. - Some error messages being displayed as
error:undefined:undefined
in the Console, e.g. in the live data view. - Missing
query
flag on CLI search commands.
In Progress
Posted: Mon, 18 Apr 2022 12:00:39 +0200
Scheduled maintenance is currently in progress. We will provide updates as necessary.
Completed
Posted: Mon, 18 Apr 2022 13:30:23 +0200
The scheduled maintenance has been completed.
