Completed: Upgrade to The Things Network v3.18.0
This is a cross-post of an incident on our The Things Network status page.
It will be updated automatically.
Scheduled: Mon, 21 Feb 2022 09:30:00 +0100 until 14:30:00 +0100
Resolved: Mon, 21 Feb 2022 14:30:36 +0100
Affected Components
- Europe 1 (eu1.cloud.thethings.network): Operational
- North America 1 (nam1.cloud.thethings.network): Operational
- Australia 1 (au1.cloud.thethings.network): Operational
Scheduled
Posted: Mon, 21 Feb 2022 08:48:30 +0100
During this maintenance window we will upgrade The Things Network v3.18.0
We do not expect noticeable downtime during this deployment.
Here is the changelog since the current version v3.17.2:
Added
- Retain at most 10 recent session keys in the Join Server. This avoids a slowly growing number of session keys in the Join Server's database.
- This requires a database migration (
ttn-lw-stack js-db migrate
- Add TTL for gateway connection stats. Can be configured with the option
gs.connection-stats-ttl
. - AWS Cloud Map cluster service discovery support:
- This method is meant to be used when DNS service discovery is unreliable. This can occur with AWS Route53 if more than 8 instances are available per service.
- The peer address should contain the service names. Ports may be specified if the service discovery entry does not have a port specified.
- The
--cluster.aws.cloud-map.namespace
configuration option can be used to configure the namespace name.
- Configuration options
is.database-max-idle-conns
andis.database-max-open-conns
to control the database connection pool of the Identity Server.
Changed
- The minimum required Redis version is now 6.2.
Deprecated
- Gateway Server setting
gs.update-connection-stats-debounce-time
is no longer valid.
Fixed
- Device activation flow with a LoRaWAN Backend Interfaces 1.1 capable Join Server.
- Join Servers using Backend Interfaces 1.1 (protocol
BI1.1
) must be configured with asender-ns-id
containing the EUI of the Network Server.
- Fix
time.Duration
flags in CLI. - Gateway Server will no longer leave permanent gateway connection stats data on the registry when crashing.
In Progress
Posted: Mon, 21 Feb 2022 09:30:24 +0100
Scheduled maintenance is currently in progress. We will provide updates as necessary.
Completed
Posted: Mon, 21 Feb 2022 14:30:36 +0100
The scheduled maintenance has been completed.
