Upgrade to The Things Network v3.16.1 (scheduled)
Scheduled: Upgrade to The Things Network v3.16.1
This is a cross-post of an incident on our The Things Network status page.
It will be updated automatically.
Scheduled: Mon, 29 Nov 2021 09:30:00 +0100 until 11:30:00 +0100
Affected Components
  • Europe 1 (eu1.cloud.thethings.network): Operational
  • North America 1 (nam1.cloud.thethings.network): Operational
  • Australia 1 (au1.cloud.thethings.network): Operational
Scheduled
Posted: Sun, 28 Nov 2021 15:43:54 +0100
During this maintenance window we will upgrade The Things Network v3.16.1
We do not expect noticeable downtime during this deployment.
Here is the changelog since the current version 3.16.0:
Added
  • Support for fine timestamps and frequency offsets sent by gateways with SX1303 concentrator using the legacy UDP protocol.
  • Support for resetting end device session context and MAC state in the Console.
  • The Content-Security-Policy header (that was previously behind the webui.csp feature flag) is now enabled by default.
  • Default Cache-Control: no-store headers.
  • Cache-Control: public, max-age=604800, immutable headers for hashed static files.
  • Experimental support for BasicStation GPS timestamps which use the wrong precision (milliseconds instead of microseconds).
    • The Gateway Server will attempt to determine the correct GPS timestamp from the provided gpstime based on the time at which the upstream message has been received.
    • This workaround will be available until the related gateway vendors will release patches for this issue.
  • Firmware version of The Things Kickstarter Gateway are written to the gateway attributes upon receiving a valid status message.
  • Desired mac settings to end device general settings in the Console.
Changed
  • Gateway server disconnects LoRa Basics Station gateways that stop sending pongs to server pings. This does not apply to gateways that don't support pongs.
  • The new plugin for reading/writing JSON in our API (that was previously behind the jsonpb.jsonplugin feature flag) is now enabled by default. All API responses should be equivalent, but in some cases object fields may be in a different order.
Fixed
  • The reported sub-band's downlink_utilization in gateway connection stats now represents the utilization of the available duty-cycle time.
  • Missing fields when admins list non-owned entities.
  • Using the correct timestamp when retreiving the "Last activity" data point for Gateways on initial page loads in the Console.
  • Events reappearing in the end device data view after clearing them when navigating back and forth.
  • Editing AWS IoT Integration region, stack name or cross-account role ARN makes The Things Stack re-initialize the integration correctly. Previously, the old AWS IoT Core endpoint was being contacted after editing these values.
Scheduled
Posted: Mon, 29 Nov 2021 08:29:30 +0100
Maintenance will begin as scheduled in 60 minutes.
The incident on our status page was just updated with new information. The first post in this topic has been updated accordingly.
