Upgrade to The Things Network v3.14.2 (completed)
Completed: Upgrade to The Things Network v3.14.2
This is a cross-post of an incident on our status page. It will be updated automatically.
Impact: Maintenance
Scheduled: Mon, 30 Aug 2021 10:30:00 +0200 until 12:30:00 +0200
Resolved: Mon, 30 Aug 2021 12:30:29 +0200
Affected Components
  • Europe 1 (eu1.cloud.thethings.network): Operational
  • North America 1 (nam1.cloud.thethings.network): Operational
  • Australia 1 (au1.cloud.thethings.network): Operational
Scheduled
Posted: Fri, 27 Aug 2021 16:42:36 +0200
During this maintenance window we will upgrade The Things Network v3.14.2
We do not expect noticeable downtime during this deployment.
Here is the changelog since the current version v3.14.1:
Added
  • CLI warnings about insecure connections.
  • CLI warnings about using the --all flag.
  • Packet Broker network listed switch in the Console.
  • Improved errors for invalid command-line flags.
  • Validation of entity attributes in the Console, with regards to maximum length for keys and values.
  • Support limiting concurrent data plane application gRPC and MQTT connections by application and tenant ID. See the resource-limiting configuration section for details.
  • CLI command to decode raw LoRaWAN frames (ttn-lw-cli lorawan decode), useful for debugging purposes.
  • Options to restore or purge deleted applications, gateways and organizations in the Console.
  • Handling of default mac settings values when manually registering end devices in the Console.
  • Add a new class_b_c_downlink_interval field that can be configured to set the minimum interval between a network initiated downlink (Class B & Class C) and an arbitrary downlink per device.
  • Retrieve count of upstream messages from the Storage Integration by end device.
    • See the new GetStoredApplicationUpCount RPC.
    • See the new ttn-lw-cli applications storage count and ttn-lw-cli end-devices storage count CLI commands.
Changed
  • The Identity Server now returns a validation error when trying to update the EUIs of an end device.
  • Network Server no longer accepts RX metadata from Packet Broker if the originating forwarder network equals the current Network Server (by NetID and cluster ID, based onns.net-id and ns.cluster-id configuration). This avoids duplicate RX metadata as well as redundant downlink scheduling attempts through Packet Broker after the cluster's Gateway Server already failed to schedule.
  • Usability of the end device import function in the Console.
    • Show a per-device report when errors occur.
    • More structural changes to the process to improve UX.
Removed
  • Packet Broker mutual TLS authentication; only OAuth 2.0 is supported now.
  • request_details from errors in the Console.
Fixed
  • Generated CLI configuration for The Things Stack Community Edition.
  • End device access with limited rights in the Console.
  • Parsing of ID6 encoded EUIs from Basic Station gateways.
  • Warnings about unknown fields when getting or searching for gateways.
  • Internal Server Errors from pkg/identityserver/store.
  • Console rendering blank pages in outdated browsers due to missing or incomplete internationalization API.
  • Error in edit user form (Console) when submitting without making any changes.
  • description field not being fetched in edit user form (admin only) in the Console.
  • Ignore invalid configuration when printing configuration with ttn-lw-cli config or ttn-lw-stack config.
  • Emails about API key changes.
  • Avoid rendering blank pages in the Console for certain errors.
  • Blank page crashes in the Console for certain browsers that do not fully support Intl API.
  • End device session keys handling in the Console.
  • Byte input width in Safari in the Console.
In Progress
Posted: Mon, 30 Aug 2021 10:30:37 +0200
Scheduled maintenance is currently in progress. We will provide updates as necessary.
Completed
Posted: Mon, 30 Aug 2021 12:30:29 +0200
The scheduled maintenance has been completed.
Do these relate to the FireFox / Chrome ESR issues?
The incident on our status page was just updated with new information. The first post in this topic has been updated accordingly.
