Unknown issue with LMIC / ESP32
I need help I use the library MCCI LoRaWAN LMIC Library With board ESP32-Wrover. The result is no data sent to TTN Application and when I apply that is used Arduino code Show results that the Unsupported Board. Do I have to fix it by changing the working board?
This is Arduino code that I use;
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#ifdef COMPILE_REGRESSION_TEST
define FILLMEIN 0
#else
warning “You must replace the values marked FILLMEIN with real values from the TTN control panel!”
define FILLMEIN (#dont edit this, edit the lines that use FILLMEIN)
#endif
static const PROGMEM u1_t NWKSKEY[16] = { FILLMEIN };
static const u1_t PROGMEM APPSKEY[16] = { FILLMEIN };
static const u4_t DEVADDR = FILLMEIN;
static uint8_t mydata = “Hello, world!”;
static osjob_t sendjob;
const unsigned TX_INTERVAL = 60;
.nss = 9,
.rxtx = LMIC_UNUSED_PIN,
.rst = 3,
.dio = {18, 19, LMIC_UNUSED_PIN},
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
Serial.println(F(“EV_SCAN_TIMEOUT”));
break;
case EV_BEACON_FOUND:
Serial.println(F(“EV_BEACON_FOUND”));
break;
case EV_BEACON_MISSED:
Serial.println(F(“EV_BEACON_MISSED”));
break;
case EV_BEACON_TRACKED:
Serial.println(F(“EV_BEACON_TRACKED”));
break;
case EV_JOINING:
Serial.println(F(“EV_JOINING”));
break;
case EV_JOINED:
Serial.println(F(“EV_JOINED”));
break;
case EV_JOIN_FAILED:
Serial.println(F(“EV_JOIN_FAILED”));
break;
case EV_REJOIN_FAILED:
Serial.println(F(“EV_REJOIN_FAILED”));
break;
case EV_TXCOMPLETE:
Serial.println(F(“EV_TXCOMPLETE (includes waiting for RX windows)”));
Serial.println(F(“Received ack”));
if (LMIC.dataLen) {
Serial.println(F(“Received “));
Serial.println(LMIC.dataLen);
Serial.println(F(” bytes of payload”));
break;
case EV_LOST_TSYNC:
Serial.println(F(“EV_LOST_TSYNC”));
break;
case EV_RESET:
Serial.println(F(“EV_RESET”));
break;
case EV_RXCOMPLETE:
Serial.println(F(“EV_RXCOMPLETE”));
break;
case EV_LINK_DEAD:
Serial.println(F(“EV_LINK_DEAD”));
break;
case EV_LINK_ALIVE:
Serial.println(F(“EV_LINK_ALIVE”));
break;
case EV_TXSTART:
Serial.println(F(“EV_TXSTART”));
break;
case EV_TXCANCELED:
Serial.println(F(“EV_TXCANCELED”));
break;
case EV_RXSTART:
break;
case EV_JOIN_TXCOMPLETE:
Serial.println(F(“EV_JOIN_TXCOMPLETE: no JoinAccept”));
break;
default:
break;
void do_send(osjob_t* j){
Serial.println(F(“OP_TXRXPEND, not sending”));
} else {
Serial.println(F(“Packet queued”));
void setup() {
// pinMode(13, OUTPUT);
// while (!Serial); // wait for Serial to be initialized
Serial.begin(115200);
delay(100); // per sample code on RF_95 test
Serial.println(F(“Starting”));
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
delay(1000);
#endif
// LMIC init
os_init();
LMIC_reset();
#ifdef PROGMEM
LMIC_setSession (0x13, DEVADDR, nwkskey, appskey);
#else
LMIC_setSession (0x13, DEVADDR, NWKSKEY, APPSKEY);
#endif
#if defined(CFG_eu868)
LMIC_setupChannel(0, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
LMIC_setupChannel(1, 868300000, DR_RANGE_MAP(DR_SF12, DR_SF7B), BAND_CENTI);      // g-band
LMIC_setupChannel(2, 868500000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
LMIC_setupChannel(3, 867100000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
LMIC_setupChannel(4, 867300000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
LMIC_setupChannel(5, 867500000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
LMIC_setupChannel(6, 867700000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
LMIC_setupChannel(7, 867900000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
LMIC_setupChannel(8, 868800000, DR_RANGE_MAP(DR_FSK,  DR_FSK),  BAND_MILLI);      // g2-band
#elif defined(CFG_us915) || defined(CFG_au915)
LMIC_selectSubBand(1);
#elif defined(CFG_as923)
#elif defined(CFG_kr920)
#elif defined(CFG_in866)
#else
# error Region not supported
#endif
LMIC_setLinkCheckMode(0);
LMIC.dn2Dr = DR_SF9;
// Set data rate and transmit power for uplink
LMIC_setDrTxpow(DR_SF7,14);
// Start job
do_send(&sendjob);
void loop() {
unsigned long now;
now = millis();
if ((now & 512) != 0) {
Serial.print(now);
digitalWrite(13, HIGH);
else {
digitalWrite(13, LOW);
os_runloop_once();
please format your post with </> tool using the post formatting tools read your own post and see if you can descript it
please reference to where you found what you are using
do you see anything in the console of you application or gateway
I appreciate that English may not be your first language, so it may be better for you to write out the problem in your own words and use Google Translate, as this phrase seems key to your issue but is not clear what you mean.
The topic title is misleading so I’ve changed it temporarily.
You’ve posted the generic ABP code for LMIC without putting any of the settings in.
Overall I’d suggest you start out with LMIC-node which has detailed instructions to get started with an ESP board.
And read the Learn section to understand the choices you are making - OTAA is preferable to ABP - these terms are explained in the learning docs.
I’m sorry. I’m new to using this platform. This is the result.
I thank you very much. I will try to write or explain to you to understand.
At this time, I use the board ESP32-Wrover Install library MCCI LoRaWAN LMIC Library and use code examples. I only change the pin to the function const lmic_pinmap lmic_pins = {… }
The results that I got Serial monitor and console application.
Thank you very much
Suphika
This:
and did you follow this suggestion:
and have you:
because the device won’t work if you don’t put the settings in to it.
The Dev & JoinEUI are public data - it’s the AppKey you need to keep secret.
It does not help the forum to post the same images twice, we can all see the replies. And any text like serial output should be copied & pasted over, not as a screen shot.
Please as a minimum fill in the settings as it says at the top of the example sketch and ensure you familiar with the basics from the Learn section.
@descartes I will try to learn and try the suggestions. thank you very much.
