Hi descartes,
Thank you for your reply.
It seems you didn’t take the huge hint I gave you about the Learn section or the explicit hint that Jac gave you to the page on dealing with bytes.
I do have other projects I need to work on here and I don’t think stating that I am not utilizing the valuable resources that you and kersing have provided after less than a day is fair. I was replying to other replies was receiving in the meantime and gauging what other subjects I should be looking into to improve my knowledge on this topic.
You really can’t hack your way through LoRaWAN without understanding the fundamentals - like the way the payload is Base64 encoded so you can’t just take the console entry and try and treat that as ASCII bytes. But what you see in the gateway console - do you know what the data is there?
Learning more about this is the reason I posted to the forum.
And if you encounter DevNonce issues, typical of using MLS 1.0.5 with LW v1.0.4, how do you clear those down so you can carry on with development?
I used a CLI command to reset join nonces.
Everyone answering here are volunteers so there is a limit to the time they can provide. If you were a maker taking baby steps that would be fine, we’d provide a steer and, most importantly, look to see you are consuming the materials you are directed to.
I understand this and I have indicated that I appreciate all the time and guidance that has been given to me. I don’t mean to appear unappreciative or unwilling to learn on my own, and I apologize if this is the impression I have given.
As this is a commercial project, you have clearly demonstrated that it needs some input from someone who knows what they are doing to get you over the hump of your first LoRaWAN project - and then maybe for the next few after. Or you take out a month, assume the role of an apprentice and start with LoRaWAN 101, building from there.
As much as I agree with you, I am powerless to do anything about this. I’m a new-grad working alone on the firmware of this project and LoRaWAN is unfamiliar to me. The Learn section and these forums are all the resources I have.
I do appreciate your time and help. I will close this thread and take more time to learn the fundamentals.
