Hello all,
I am trying to connect a Multitech Conduit (MLinux, version 5.3.0) to The Things Stack (v3). I have managed to connect the gateway to TTS using the ttn-packet-forwarder, and it works perfectly fine. Now, I’d like to try get the gateway connecting using Basics Station. I am having an issues with getting CUPS to retrieve the LNS credentials.
At the moment this is just for testing purposes, so I am running TTS as localhost (so I have removed ports 80 and 443 from docker-compose.yml and added “1885:1885”, “8885:8885”, and appended the port to the static ip of my server in ttn-lw-stack-docker.yml). I am also using custom certificates, and have generated a key.pem, cert.pem, and ca.pem using the instructions provided here: Certificates | The Things Stack for LoRaWAN
To connect using Basics Station, on the TTS end, I modified the registered gateway to add a CUPS and an LNS API key giving the permissions requested in the instructions, and configured CUPS to send the LNS API key.
On the gateway, I did a clean install of the gateway and installed Basics Station using the instructions provided in the “Installation on MTCDT/MTCAP” of this page: MultiTech Developer Resources » Running Basic Station on Conduit
I then populated the /var/config/lora folder of the gateway with the cups.key, cups.trust, cups.uri, and station.conf, with the following format:
cups.key: “Authorization: Bearer {CUPS_API_KEY}”
cups.trust: “{SAME_AS_ca.pem_ON_THE_LNS}”
cups.uri: “https://{IP_ADDRESS_OF_LNS}:8887”
station.conf: "{"SX1301_conf: {standard channel allocation for EU868},
“gateway_conf: {
“forward_crc_disabled”: false,
“forward_crc_error”: true,
“forward_crc_valid”: true,
“gateway_ID”: “{GATEWAY_ID_ON_LNS}”,
“keepalive_interval”: 10,
“push_timeout_ms”: 100,
“serv_port_down”: 20000,
“serv_port_up”: 20000,
“server_address”: “{IP_ADDRESS_OF_LNS}”,
“stat_interval”: 30,
“autoquit_threshold”: 60
However, when I run the basics station, CUPS never retrieves the LNS API key, though the debug information is rather lacking:
2021-03-18 10:27:45.020 [SYS:INFO] Logging : stderr (maxsize=10485760, rotate=3)
2021-03-18 10:27:45.021 [SYS:INFO] Station Ver : 2.0.3(mlinux/std) 2020-03-11 15:07:03
2021-03-18 10:27:45.022 [SYS:INFO] Package Ver : (null)
2021-03-18 10:27:45.024 [SYS:INFO] proto EUI : 0:8:4a:ab80 (/sys/class/net/eth0/address)
2021-03-18 10:27:45.024 [SYS:INFO] prefix EUI : ::1 (builtin)
2021-03-18 10:27:45.024 [SYS:INFO] Station EUI : 8:ff:fe4a:ab80
2021-03-18 10:27:45.024 [SYS:INFO] Station home: ./ (builtin)
2021-03-18 10:27:45.024 [SYS:INFO] Station temp: /var/tmp/ (builtin)
2021-03-18 10:27:45.227 [TCE:INFO] Starting TC engine
2021-03-18 10:27:45.228 [TCE:ERRO] No TC URI configured
2021-03-18 10:27:45.228 [CUP:INFO] Starting a CUPS session in 0 seconds.
2021-03-18 10:27:45.229 [TCE:INFO] INFOS reconnect backoff 0s (retry 0)
2021-03-18 10:27:45.229 [CUP:INFO] Starting a CUPS session now.
2021-03-18 10:27:45.229 [CUP:INFO] Connecting to CUPS ... https://{IP_ADDRESS_OF_LNS}:8885 (try #1)
2021-03-18 10:27:45.233 [any:INFO] cert. version : 3
serial number : 73:B4:31:F6:A8:66:E3:84:E8:16:62:71:A6:97:76:24:C3:87:00:3D
issuer name : C=NL, ST=Noord-Holland, L=Amsterdam, O=The Things Demo
subject name : C=NL, ST=Noord-Holland, L=Amsterdam, O=The Things Demo
issued on : 2021-03-12 10:43:00
expires on : 2026-03-11 10:43:00
signed using : ECDSA with SHA256
EC key size : 256 bits
basic constraints : CA=true
key usage : Key Cert Sign, CRL Sign
2021-03-18 10:27:45.233 [AIO:INFO] cups has no cert configured - running server auth and client auth with token
2021-03-18 10:27:45.280 [TCE:ERRO] No TC URI configured
2021-03-18 10:27:45.282 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)
2021-03-18 10:27:46.272 [CUP:INFO] Interaction with CUPS failed - retrying in 1m
2021-03-18 10:27:55.284 [TCE:ERRO] No TC URI configured
2021-03-18 10:27:55.284 [TCE:INFO] INFOS reconnect backoff 20s (retry 2)
I installed Basics Station on my laptop and tried running it locally, and got the same issue but with a bit more information:
2021-03-18 11:10:29.385 [SYS:INFO] Logging : stderr (maxsize=10000000, rotate=3)
2021-03-18 11:10:29.385 [SYS:INFO] Station Ver : 2.0.5(linux/std) 2021-03-17 13:24:33
2021-03-18 11:10:29.385 [SYS:INFO] Package Ver : 1.0.0
2021-03-18 11:10:29.385 [SYS:INFO] proto EUI : 0:242:fc72:bf64 (/sys/class/net/br-c39b1fdb300d/address)
2021-03-18 11:10:29.385 [SYS:INFO] prefix EUI : ::1 (builtin)
2021-03-18 11:10:29.385 [SYS:INFO] Station EUI : 242:fcff:fe72:bf64
2021-03-18 11:10:29.385 [SYS:INFO] Station home: ./ (builtin)
2021-03-18 11:10:29.385 [SYS:INFO] Station temp: /var/tmp/ (builtin)
2021-03-18 11:10:29.586 [TCE:INFO] Starting TC engine
2021-03-18 11:10:29.586 [TCE:ERRO] No TC URI configured
2021-03-18 11:10:29.586 [CUP:INFO] Starting a CUPS session in 0 seconds.
2021-03-18 11:10:29.586 [TCE:INFO] Router rejected or retry limit reached. Invoking CUPS.
2021-03-18 11:10:29.586 [TCE:INFO] Terminating TC engine
2021-03-18 11:10:29.586 [CUP:INFO] Starting a CUPS session now.
2021-03-18 11:10:29.586 [CUP:INFO] Connecting to CUPS ... https://{IP_ADDRESS_OF_LNS}:8885 (try #1)
2021-03-18 11:10:29.586 [any:INFO] ./cups.trust:
cert. version : 3
key usage : Key Cert Sign,2021-03-18 11:10:29.586 [AIO:INFO] cups has no cert configured - running server auth and client auth with token
2021-03-18 11:10:29.632 [CUP:VERB] Retrieving update-info from CUPS https://{IP_ADDRESS_OF_LNS}:8885...
2021-03-18 11:10:29.686 [AIO:ERRO] [3] Send failed: X509 - Certificate verification failed, e.g. CRL, CA or signature check failed
2021-03-18 11:10:29.686 [AIO:DEBU] [3] HTTP connection shutdown...
2021-03-18 11:10:29.686 [CUP:INFO] Interaction with CUPS failed - retrying in 1s
2021-03-18 11:10:29.686 [TCE:INFO] Starting TC engine
2021-03-18 11:10:29.686 [TCE:ERRO] No TC URI configured
2021-03-18 11:10:29.686 [TCE:INFO] Router rejected or retry limit reached. Invoking CUPS.
2021-03-18 11:10:29.686 [TCE:INFO] Terminating TC engine
2021-03-18 11:10:29.686 [CUP:INFO] Starting a CUPS session in 1 seconds.
2021-03-18 11:10:30.687 [CUP:INFO] Starting a CUPS session now.
So it looks like my configuration of CUPS is incorrect. Could anyone verify for me if the cups.x files I am using are correct?
Or if there are any other mistakes I have made in the configuration?
