Unable to Join through OTAA , It worked only for one time
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
// 0x70.
static const u1_t PROGMEM APPEUI[8]={ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
static const u1_t PROGMEM DEVEUI[8]={ 0x9B, 0xB1, 0x04, 0xD0, 0x7E, 0xD5, 0xB3, 0x70 };
// practice, a key taken from ttnctl can be copied as-is.
// The key shown here is the semtech default key.
static const u1_t PROGMEM APPKEY[16] = { 0x6B, 0xEC, 0xF4, 0xD8, 0x6C, 0x84, 0x78, 0x7A, 0xE3, 0xB2, 0x36, 0xC5, 0x1C, 0x37, 0x6F, 0x55 };
void os_getDevKey (u1_t* buf) { memcpy_P(buf, APPKEY, 16);}
static uint8_t mydata = “Hello 3A!”;
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 30;
// Pin mapping
.nss = 10,
.rxtx = LMIC_UNUSED_PIN,
.rst = 9,
.dio = {2, 6, 7},
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
Serial.println(F(“EV_SCAN_TIMEOUT”));
break;
case EV_BEACON_FOUND:
Serial.println(F(“EV_BEACON_FOUND”));
break;
case EV_BEACON_MISSED:
Serial.println(F(“EV_BEACON_MISSED”));
break;
case EV_BEACON_TRACKED:
Serial.println(F(“EV_BEACON_TRACKED”));
break;
case EV_JOINING:
Serial.println(F(“EV_JOINING”));
break;
case EV_JOINED:
Serial.println(F(“EV_JOINED”));
        // during join, but not supported by TTN at this time).
        LMIC_setLinkCheckMode(0);
        break;
    case EV_RFU1:
        Serial.println(F("EV_RFU1"));
        break;
    case EV_JOIN_FAILED:
        break;
    case EV_REJOIN_FAILED:
        break;
        break;
    case EV_TXCOMPLETE:
        if (LMIC.dataLen) {
          Serial.println(LMIC.dataLen);
        // Schedule next transmission
        break;
    case EV_LOST_TSYNC:
        break;
    case EV_RESET:
        break;
    case EV_RXCOMPLETE:
        // data received in ping slot
        break;
    case EV_LINK_DEAD:
        break;
    case EV_LINK_ALIVE:
        break;
     default:
        break;
void do_send(osjob_t* j){
Serial.println(F(“OP_TXRXPEND, not sending”));
} else {
Serial.println(F(“Packet queued”));
void setup() {
Serial.begin(115200);
Serial.println(F(“Starting”));
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
delay(1000);
#endif
// LMIC init
os_init();
LMIC_reset();
do_send(&sendjob);
void loop() {
os_runloop_once();
Screenshot (14)
Screenshot (15)
