Greetings-
I am currently having issues connecting a client via CUPS to my TTS v3 running the Open
Source version.
I believe the server is giving the client a 500 error, I am sure there is a problem in my config but I am unclear where.
If I for go CUPS and configure LNS directly, I am able to connect.
The Things Stack for LoRaWAN: ttn-lw-stack
Version: 3.13.1
Build date: 2021-06-04T09:24:40Z
Git commit: 76bc6cf3c
Go version: go1.16.5
OS/Arch: linux/arm
The server log shows:
Jun 12 05:00:17 console ttn-lw-stack[4516]: DEBUG Run database query duration=2ms grpc.method=GetIdentifiersForEUI grpc.service=ttn.lorawan.v3.GatewayRegistry namespace=db query=SELECT id, created_at, updated_at, deleted_at, gateway_id, gateway_eui FROM "gateways" WHERE "gateways"."deleted_at" IS NULL AND ((gateway_eui = $1)) ORDER BY "gateways"."id" ASC LIMIT 1 request_id=01F7Z9F535C4D9V44FEMQA98H5 rows=1 source=gateway_store.go:118 values=[B827EBFFFE63DE5E]
Jun 12 05:00:17 console ttn-lw-stack[4516]: INFO Finished unary call duration=3ms grpc.method=GetIdentifiersForEUI grpc.service=ttn.lorawan.v3.GatewayRegistry namespace=grpc peer.address=pipe request_id=01F7Z9F535C4D9V44FEMQA98H5
Jun 12 05:00:17 console ttn-lw-stack[4516]: DEBUG Found gateway for EUI gateway_eui=B827EBFFFE63DE5E gateway_uid=odingate http.method=POST http.path=/update-info namespace=web peer.address=192.168.1.15:58554 request_id=01F7Z9F534KMP263A8FEFDYB7A
Jun 12 05:00:17 console ttn-lw-stack[4516]: DEBUG Run database query duration=1ms gateway_eui=B827EBFFFE63DE5E http.method=POST http.path=/update-info namespace=db peer.address=192.168.1.15:58554 query=SELECT * FROM "api_keys" WHERE ("api_keys"."api_key_id" = $1) ORDER BY "api_keys"."id" ASC LIMIT 1 request_id=01F7Z9F534KMP263A8FEFDYB7A rows=1 source=api_key_store.go:117 values=[BQYOQ5QOARIM2GO2AVM456OB7C5EUYTDXZNKMJY]
Jun 12 05:00:17 console ttn-lw-stack[4516]: DEBUG Run database query duration=1ms gateway_eui=B827EBFFFE63DE5E http.method=POST http.path=/update-info namespace=db peer.address=192.168.1.15:58554 query=SELECT id as uuid, gateway_id as friendly_id FROM "gateways" WHERE (id in ($1)) request_id=01F7Z9F534KMP263A8FEFDYB7A rows=1 source=membership.go:73 values=[91681ae5-f3e4-4ca5-8c1d-2bc2672a54b0]
Jun 12 05:00:17 console ttn-lw-stack[4516]: DEBUG Run database query duration=2ms gateway_eui=B827EBFFFE63DE5E http.method=POST http.path=/update-info namespace=db peer.address=192.168.1.15:58554 query=SELECT id, created_at, updated_at, deleted_at, gateway_id, gateway_eui, status_public, location_public FROM "gateways" WHERE "gateways"."deleted_at" IS NULL AND ((gateway_id = $1) AND (gateway_eui = $2)) ORDER BY "gateways"."id" ASC LIMIT 1 request_id=01F7Z9F534KMP263A8FEFDYB7A rows=1 source=gateway_store.go:118 values=[odingate B827EBFFFE63DE5E]
Jun 12 05:00:17 console ttn-lw-stack[4516]: DEBUG Authorized with The Things Stack token gateway_eui=B827EBFFFE63DE5E http.method=POST http.path=/update-info namespace=web peer.address=192.168.1.15:58554 request_id=01F7Z9F534KMP263A8FEFDYB7A
Jun 12 05:00:17 console ttn-lw-stack[4516]: DEBUG Run database query duration=2ms grpc.method=Get grpc.service=ttn.lorawan.v3.GatewayRegistry namespace=db query=SELECT * FROM "api_keys" WHERE ("api_keys"."api_key_id" = $1) ORDER BY "api_keys"."id" ASC LIMIT 1 request_id=01F7Z9F53SDF05B0TEBHGCZZPB rows=1 source=api_key_store.go:117 values=[BQYOQ5QOARIM2GO2AVM456OB7C5EUYTDXZNKMJY]
Jun 12 05:00:17 console ttn-lw-stack[4516]: DEBUG Run database query duration=1ms grpc.method=Get grpc.service=ttn.lorawan.v3.GatewayRegistry namespace=db query=SELECT id as uuid, gateway_id as friendly_id FROM "gateways" WHERE (id in ($1)) request_id=01F7Z9F53SDF05B0TEBHGCZZPB rows=1 source=membership.go:73 values=[91681ae5-f3e4-4ca5-8c1d-2bc2672a54b0]
Jun 12 05:00:17 console ttn-lw-stack[4516]: DEBUG Run database query duration=2ms grpc.method=Get grpc.service=ttn.lorawan.v3.GatewayRegistry namespace=db query=SELECT id, created_at, updated_at, deleted_at, gateway_id, gateway_eui, status_public, location_public FROM "gateways" WHERE "gateways"."deleted_at" IS NULL AND ((gateway_id = $1) AND (gateway_eui = $2)) ORDER BY "gateways"."id" ASC LIMIT 1 request_id=01F7Z9F53SDF05B0TEBHGCZZPB rows=1 source=gateway_store.go:118 values=[odingate B827EBFFFE63DE5E]
Jun 12 05:00:17 console ttn-lw-stack[4516]: DEBUG Run database query duration=2ms grpc.method=Get grpc.service=ttn.lorawan.v3.GatewayRegistry namespace=db query=SELECT id, created_at, updated_at, deleted_at, gateway_id, gateway_eui, auto_update, frequency_plan_id, gateway_server_address, lbs_lns_secret, target_cups_key, target_cups_uri, update_channel, brand_id, model_id, hardware_version, firmware_version FROM "gateways" WHERE "gateways"."deleted_at" IS NULL AND ((gateway_id = $1) AND (gateway_eui = $2)) ORDER BY "gateways"."id" ASC LIMIT 1 request_id=01F7Z9F53SDF05B0TEBHGCZZPB rows=1 source=gateway_store.go:118 values=[odingate B827EBFFFE63DE5E]
Jun 12 05:00:17 console ttn-lw-stack[4516]: DEBUG Run database query duration=1ms grpc.method=Get grpc.service=ttn.lorawan.v3.GatewayRegistry namespace=db query=SELECT * FROM "attributes" WHERE ("entity_id" IN ($1) AND "entity_type" = $2) ORDER BY "attributes"."id" ASC request_id=01F7Z9F53SDF05B0TEBHGCZZPB rows=0 source=gateway_store.go:118 values=[91681ae5-f3e4-4ca5-8c1d-2bc2672a54b0 gateway]
Jun 12 05:00:17 console ttn-lw-stack[4516]: WARN No encryption key defined, return stored LBS LNS Secret value grpc.method=Get grpc.service=ttn.lorawan.v3.GatewayRegistry namespace=identityserver request_id=01F7Z9F53SDF05B0TEBHGCZZPB
Jun 12 05:00:17 console ttn-lw-stack[4516]: INFO Finished unary call auth.token_id=BQYOQ5QOARIM2GO2AVM456OB7C5EUYTDXZNKMJY auth.token_type=APIKey duration=22ms grpc.method=Get grpc.request.gateway_id=odingate grpc.service=ttn.lorawan.v3.GatewayRegistry namespace=grpc peer.address=pipe request_id=01F7Z9F53SDF05B0TEBHGCZZPB
Jun 12 05:00:17 console ttn-lw-stack[4516]: DEBUG Configure LNS gateway_eui=B827EBFFFE63DE5E http.method=POST http.path=/update-info lns_uri=console.theodin.network namespace=web peer.address=192.168.1.15:58554 request_id=01F7Z9F534KMP263A8FEFDYB7A
Jun 12 05:00:17 console ttn-lw-stack[4516]: ERROR Server error address=console.theodin.network auth.token_id=BQYOQ5QOARIM2GO2AVM456OB7C5EUYTDXZNKMJY auth.token_type=APIKey duration=56.2ms error=error:pkg/basicstation/cups:server_trust (failed to fetch server trust for address `console.theodin.network`) error_cause=remote error: tls: internal error http.method=POST http.path=/update-info http.status=500 namespace=web peer.address=192.168.1.15:58554 request_id=01F7Z9F534KMP263A8FEFDYB7A
My Server config looks like this:
# The Things Stack for LoRaWAN Configuration File
log:
level: 'debug'
is:
database-uri: postgresql://thethingsstack:<--Remove Data for posting-->@<--Remove Data for posting-->:5432/ttn_lorawan?sslmode=require
admin-rights:
all: true
user-registration:
admin-approval:
required: true
contact-info-validation:
required: true
password-requirements:
reject-user-id: true
reject-common: true
oauth:
ui:
site-name: "The Odin Things Network"
canonical-url: 'https://console.theodin.network/oauth'
is:
base-url: 'https://console.theodin.network/api/v3'
email:
sender-name: 'The Odin Things Network'
sender-address: 'noreply@theodin.network'
network:
console-url: 'https://console.theodin.network/console'
identity-server-url: 'https://console.theodin.network/oauth'
# Send email with Sendgrid
provider: sendgrid
sendgrid:
api-key: '<--Remove Data for posting-->'
http:
listen: ':80'
listen-tls: ':443'
cookie:
# To generate 32 bytes (openssl rand -hex 32)
block-key: '<--Remove Data for posting-->'
# To generate 64 bytes (openssl rand -hex 64)
hash-key: '<--Remove Data for posting-->'
metrics:
password: '<--Remove Data for posting-->'
pprof:
tls:
source: 'acme'
acme:
enable: true
default-host: 'console.theodin.network'
dir: '/var/lib/ttn/certs'
email: 'admin@theodin.network'
hosts:
- console.theodin.network
frequency-plans:
config-source: 'directory'
directory: '/var/lib/ttn/frequency-plans/'
events:
backend: redis
redis:
store:
enable: true
cluster:
keys: '<--Remove Data for posting-->'
gs:
basic-station:
fallback-frequency-plan-id: 'US_902_928_FSB_2'
listen: 'console.theodin.network:1887'
listen-tls: 'console.theodin.network:8887'
mqtt:
public-address: 'console.theodin.network:1882'
public-tls-address: 'console.theodin.network:8883'
mqtt-v2:
public-address: 'console.theodin.network:1881'
public-tls-address: 'console.theodin.network:8881'
gcs:
basic-station:
allow-cups-uri-update: true
default:
lns-uri: 'wss://console.theodin.network:8887'
owner-for-unknown:
account-type: 'user'
id: '<--Remove Data for posting-->'
require-auth: false
the-things-gateway:
default:
mqtt-server: 'mqtts://console.theodin.network:8881'
dr:
directory: '/var/lib/ttn/devices'
store:
bleve:
search-paths: '/var/lib/ttn/devices'
as:
mqtt:
public-address: 'console.theodin.network:1883'
console:
ui:
descriptions: 'Welcome to the Odin Network'
canonical-url: 'https://console.theodin.network/console'
is:
gs:
ns:
as:
js:
gcs:
qrg:
edtc:
oauth:
authorize-url: 'https://console.theodin.network/oauth/authorize'
token-url: 'https://console.theodin.network/oauth/token'
logout-url: 'https://console.theodin.network/oauth/logout'
client-id: 'console'
client-secret: '<--Remove Data for posting-->'
redis:
address: '127.0.0.1:6379'
database: 1
