I am now stumped with what I thought would be a simple cog to implement in a bigger solution.
I am unable to connect to my TTN application using MQTT.
I first ran Node-Red within a docker container on a Pi5, which didn’t connect. I just keep getting Connection failed to broker message in the log file.
I tried with TLS and without, using tcp protocol and not, mapping app ports in docker and still nothing.
So I tried directly inside the Pi5 with Node-Red (not in a docker container) and I get the same problem.
I was thinking it might be network related, so removed all ‘iptables’ on the Pi5 (alllowing all traffic) and still no luck.
Convinced it might be my home network, I now have a Node-Red instance running in the cloud (FlowFuse) and get the same message, again using all options I can think of.
The only connection I have been able to make it using MQTT Explorer on my Mac, and using npx mqtt sub from a command line.
That got me thinking it must be the MQTT node in Node-Red, so I connected it to the free Mosquitto server, and there were no problems at all.
The server I am connecting to is eu1.cloud.thethings.industries for which I get the same IP resolution each time…
Does anyone have any other ideas or thoughts as to why this might be happening.
Does anyone know how to view detailed logs on The Things Stack application to even see if the connection is being refused?
Same server, same user credentials, both with and without TLS (MQTT Explorer works with and without TLS), same topic…
I have tried to keep the same where ever so that once I get a connection that works and I understand, I can re-configure it in the place I actually want it.
I was convinced it was at my [network] end, but when using FuseFlow I get the same, ruling out my network.
Most likely as the resource limit idea would be an issue if you tried to connect 50+ clients at the same time, but not one.
You could spin up a virtual Debian on your Mac to try out Node-RED - not exactly the same as running on a Pi but close enough as all the sources are the same.
I have dropped all other connections that I can, including user sessions listed in the CLI).
Still no luck.
I am unable to see if there are any ‘active’ MQTT sessions (as in I don’t know where to look either)
I guessed there might be a limit on MQTT connections to TTN, and have tried looking for the setting (on the cloud discovery version) but only found settings for on-premise deployments.
But then what confuses me is that I can get multiple clients connecting at the same time, all with same credentials etc and from different machines, but not the Node-Red connections.
Update:
I compared the Wireshark logs between NodeRed and MQTTX to see if there were any differences.
Thankfully, the trace shows Msg length, ClientID length, User length etc…
It seems that when the user name has been copied into NodeRed, an extra space has been left at the beginning. which I have missed when I have checked all else.
It has not left an extra space in front of the password, so maybe a UI issue in NodeRed, or simply user error.
(Strange how it wasn’t return incorrect credentials user code though)
My NodeRed(s) are now all connecting with no issues.
Many thanks to those who have helped, and good luck to anyone else to find this and it helps them too.
