Hello
I have been running a TTS on a VM (Ubuntu + docker + stack) for like 18 months without problems. But now i just can’t add anymore device. Tried 2 different models, console always show a mic_mismatch error on join request.
AppEUI and DevEUI are corrects.
Region is correct (EU868)
Lora Version is correct (1.0.3).
Device is a few meters from gateway
Several identical devices are still functionning and sending data, TTS is working fine, I just can’t add anymore.
Ubuntu has been patched, rebooted, gateway also, no effect.
Some technical details
Device: Dragino LDS02 door sensor, pretty straighforward to set up.
Docker images versions:
things@ttn:/the-things-stack$ sudo docker-compose images
Container Repository Tag Image Id Size
the-things-stack_postgres_1 postgres 15.2 bf700010ce28 378.7 MB
the-things-stack_redis_1 redis 7.2-rc 22a9e397686e 137.7 MB
the-things-stack_stack_1 thethingsnetwork/lorawan-stack 3.25.0 79160cdb2f60 444.8 MB
Join request:
"name": "ns.up.join.cluster.attempt",
"time": "2024-08-03T05:18:24.048235056Z",
"identifiers": [
"device_ids": {
"device_id": "dragino-porte-17",
"application_ids": {
"application_id": "egh-test"
"dev_eui": "A840419D7183F278",
"join_eui": "A840410000000107"
"data": {
"@type": "type.googleapis.com/ttn.lorawan.v3.JoinRequest",
"raw_payload": "AAcBAAAAQUCoePKDcZ1BQKhoBEncX/4=",
"payload": {
"m_hdr": {},
"mic": "Sdxf/g==",
"join_request_payload": {
"join_eui": "A840410000000107",
"dev_nonce": "0468"
"dev_addr": "0125C359",
"selected_mac_version": "MAC_V1_0_3",
"net_id": "000000",
"downlink_settings": {
"rx2_dr": 3
"rx_delay": 5,
"cf_list": {
"freq": [
8671000,
8673000,
8675000,
8677000,
8679000
"correlation_ids": [
"gs:conn:01J4AZEDBSB8DK1XCM5TESSGGE",
"gs:up:host:01J4AZEDBZ2NCZVDSB0MEAAYYT",
"gs:uplink:01J4BASE9E17BQ3W4CTKK4A987",
"ns:uplink:01J4BASE9FFCH86FZ903DJM82K",
"rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01J4BASE9FGA70YRWZRPMKZBW4"
"consumed_airtime": "0.061696s"
"origin": "3bbb444e1d52",
"visibility": {
"rights": [
"unique_id": "01J4BASE9GPMHRE4YX6ZCRV8NH"
Join Request answer:
"name": "ns.up.join.cluster.fail",
"time": "2024-08-03T05:18:24.050607453Z",
"identifiers": [
"device_ids": {
"data": {
"namespace": "pkg/joinserver",
"name": "mic_mismatch",
"message_format": "MIC mismatch",
"correlation_id": "7fb3905801c2447c8c2b6fc78f05dbc2",
"code": 3
"visibility": {
"rights": [
"unique_id": "01J4BASE9J1Q46K9A12XBJV51Q"
Gateway:
Mikrotik LTAP, up to date (v7.15) and rebooted.
Any ideas?
