tibbe
(Tibbe)
November 10, 2019, 12:25pm
1
Hi!
If I want to be compliant for EU ETSI (868MHz) max 25mW Tx power using SX1276 chip and a stick antenna with +2 dBi gain, what TX power level should I use?
Right now I use 14dBm setting but I’m not sure if you have to reduce it, if using the antenna?
Thanks in advance!
jreiss
(Jason Reiss)
November 10, 2019, 1:08pm
2
The radio can output at +14 dBm with the +2 dBi antenna for total EIRP +16 dBm remaining below the 25 mW (+14 dBm ERP) limit.
EIRP = ERP + 2.15 dBm
Effective radiated power (ERP), synonymous with equivalent radiated power, is an IEEE standardized definition of directional radio frequency (RF) power, such as that emitted by a radio transmitter. It is the total power in watts that would have to be radiated by a half-wave dipole antenna to give the same radiation intensity (signal strength in watts per square meter) as the actual source at a distant receiver located in the direction of the antenna's strongest beam (main lobe). ERP measures t...
