The TTOG radio settings central frequency was set 9026, so just as a guess i changed it to 9043 as that seems the middle of what the NODE was using via the TTIG. Then i rebooted the TTOG.
Finally the TTN gateway overview shows 2 received messages, 0 transmitted. under the traffic tab it shows one message from the NODE. I have tried to send more messages, but now we are back to nothing new showing up on the traffic tab.
`INFO: JSON up: {"stat":{"time":"2020-01-30 17:57:37 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0}}
##### END #####
# no valid GPS coordinates available yet
# Invalid time reference (age: 1580407057 sec)
### [GPS] ###
# SX1301 time (PPS): 182572847
### [JIT] ###
# BEACON rejected: 0
# BEACON sent so far: 0
# BEACON queued: 0
# TX errors: 0
# PULL_DATA sent: 3 (100.00% acknowledged)
### [DOWNSTREAM] ###
# PUSH_DATA acknowledged: 100.00%
# PUSH_DATA datagrams sent: 1 (113 bytes)
### [UPSTREAM] ###
##### 2020-01-30 17:57:37 GMT #####
WARNING: [gps] could not get GPS time from GPS
INFO: [down] PULL_ACK received in 34 ms
INFO: [down] PULL_ACK received in 33 ms
INFO: [down] PULL_ACK received in 37 ms
INFO: [up] PUSH_ACK received in 36 ms
JSON up: {"stat":{"time":"2020-01-30 17:57:07 GMT","rxnb":2,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0}}
##### END #####
# Invalid time reference (age: 1580407027 sec)
### [GPS] ###
### [JIT] ###
# BEACON queued: 0
# TX errors: 0
# CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
# RF packets received by concentrator: 2
### [UPSTREAM] ###
##### 2020-01-30 17:57:07 GMT #####
INFO: Enabling GPS mode for concentrator's counter.
INFO: host/sx1301 time offset=(1580406845s:39737µs) - drift=-1631µs
INFO: Disabling GPS mode for concentrator's counter...
INFO: [up] PUSH_ACK received in 35 ms
JSON up: {"stat":{"time":"2020-01-30 17:56:37 GMT","rxnb":1,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0}}
##### END #####
# Invalid time reference (age: 1580406997 sec)
### [GPS] ###
# SX1301 time (PPS): 122570855
### [JIT] ###
# BEACON queued: 0
# TX errors: 0
# RF packets received by concentrator: 1
### [UPSTREAM] ###
##### 2020-01-30 17:56:37 GMT #####
JSON up: {"stat":{"time":"2020-01-30 17:56:07 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0}}
##### END #####
# Invalid time reference (age: 1580406967 sec)
### [GPS] ###
### [JIT] ###
# BEACON queued: 0
# TX errors: 0
### [UPSTREAM] ###
##### 2020-01-30 17:56:07 GMT #####
INFO: host/sx1301 time offset=(1580406845s:41368µs) - drift=-30514µs
INFO: [up] PUSH_ACK received in 37 ms
JSON up: {"stat":{"time":"2020-01-30 17:55:37 GMT","rxnb":2,"rxok":1,"rxfw":1,"ackr":100.0,"dwnb":0,"txnb":0}}
##### END #####
# Invalid time reference (age: 1580406937 sec)
### [GPS] ###
# SX1301 time (PPS): 62539850
### [JIT] ###
# BEACON queued: 0
# TX errors: 0
# PUSH_DATA datagrams sent: 2 (346 bytes)
# RF packets forwarded: 1 (19 bytes)
# CRC_OK: 50.00%, CRC_FAIL: 50.00%, NO_CRC: 0.00%
### [UPSTREAM] ###
##### 2020-01-30 17:55:37 GMT #####
JSON up: {"rxpk":[{"tmst":63109395,"chan":1,"rfch":0,"freq":904.200000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":-4.2,"lsnr_min":-9.8,"lsnr_max":-2.5,"rssi":-79,"size":19,"data":"QBIuAiYADQACyC5XAPCzEfAPjw=="}]}
INFO: Received pkt from mote: 26022E12 (fcnt=13)
JSON up: {"stat":{"time":"2020-01-30 17:55:07 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0}}
##### END #####
# Invalid time reference (age: 1580406907 sec)
### [GPS] ###
INFO: host/sx1301 time offset=(1580406845s:71882µs) - drift=-30581µs
### [JIT] ###
# BEACON queued: 0
# TX errors: 0
# PUSH_DATA datagrams sent: 1 (111 bytes)
### [UPSTREAM] ###
##### 2020-01-30 17:55:07 GMT #####
JSON up: {"stat":{"time":"2020-01-30 17:54:37 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0}}
##### END #####
# Invalid time reference (age: 1580406877 sec)
### [GPS] ###
# SX1301 time (PPS): 2508551
### [JIT] ###
# BEACON queued: 0
# TX errors: 0
# PUSH_DATA acknowledged: 0.00%
# PUSH_DATA datagrams sent: 0 (0 bytes)
### [UPSTREAM] ###
##### 2020-01-30 17:54:37 GMT #####
INFO: [down] PULL_ACK received in 36 ms
INFO: host/sx1301 time offset=(1580406845s:102463µs) - drift=614095231µs
INFO: [main] concentrator started, packet can now be received
INFO: FPGA supported features: [TX filter] [Spectral Scan] [LBT]
INFO: [main] TTY port /dev/ttyS3 open for GPS synchronization
INFO: Beaconing information descriptor is set to 0
INFO: Beaconing TX power is set to 14dBm
INFO: Beaconing modulation bandwidth is set to 500000Hz
INFO: Beaconing datarate is set to SF12
INFO: Beaconing channel frequency step is set to 600000Hz
INFO: Beaconing channel number is set to 8
INFO: Beaconing signal will be emitted at 923300000 Hz
INFO: Beaconing period is configured to 128 seconds
INFO: Reference altitude is configured to 0 meters
INFO: Reference longitude is configured to 0.000000 deg
INFO: Reference latitude is configured to 0.000000 deg
INFO: GPS serial port path is configured to "/dev/ttyS3"
INFO: packets received with no CRC will NOT be forwarded
INFO: packets received with a CRC error will NOT be forwarded
INFO: packets received with a valid CRC will be forwarded
INFO: upstream PUSH_DATA time-out is configured to 100 ms
INFO: statistics display interval is configured to 30 seconds
INFO: downstream keep-alive interval is configured to 10 seconds
INFO: downstream port is configured to "1700"
INFO: upstream port is configured to "1700"
INFO: server hostname or IP address is configured to "router.us.thethings.network"
INFO: /app/cfg/global_conf_0.json does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: FSK channel 8 disabled
INFO: Lora standard channel 8 disabled
INFO: Lora multi-SF channel 7> radio 1, IF 300000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 6> radio 1, IF 100000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 5> radio 1, IF -100000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 4> radio 1, IF -300000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 3> radio 0, IF 300000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 2> radio 0, IF 100000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 1> radio 0, IF -100000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 0> radio 0, IF -300000 Hz, 125 kHz bw, SF 7 to 12
INFO: radio 1 enabled (type SX1257), center frequency 903400000, RSSI offset -166.000000, tx enabled 0, tx_notch_freq 0
INFO: radio 0 enabled (type SX1257), center frequency 904300000, RSSI offset -166.000000, tx enabled 1, tx_notch_freq 129000
INFO: Configuring TX LUT with 16 indexes
INFO: antenna_gain 2 dBi
INFO: LBT is disabled
INFO: lorawan_public 1, clksrc 1
INFO: /app/cfg/global_conf_0.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
INFO: found global configuration file /app/cfg/global_conf_0.json, parsing it
INFO: Use SPI dev : /dev/spidev0.0
INFO: gateway MAC address is configured as 000080029C2B29C9
INFO: Little endian host
Version: 5.0.1;
*** Lora concentrator HAL library version info ***
Version: 4.0.1
*** Beacon Packet Forwarder for Lora Gateway ***
