Hi Guys,
I updated our Things Outdoor Gateway yesterday, to support Basics Station.
Does anyone have any experience of this?
EUI looks like it has changed (looking at logs).
I have installed the Trust certificate, and API Key LNS file… But all I see is Websocket back off requests in the logs.
Only obvious pointer is the internal clock at default of 2012. From experience time/date and certificates don’t play nicely if not sync’d.
… Are there any SSH details out there to set NTP?
How did you upgrade TTOG to support BasicsStation? Can you please point me to the firmware? Thanks in advance.
Thanks for sharing the firmware! Were you able to configure CUPS and LNS successfully? Are there any issues with the NTP and certificates as you mentioned in the previous post?
Regards,
Janakiram
Just make sure the internal clock is synchronised (check the logs in the console)
If not, you will need to SSH to the TTOG and set the time/date.
Didnt use CUPS, just the manual LNS.
I’m trying to register a new TTOG gateway using the Basic Station… but so far unsuccessful.
Can you share the steps for LNS?
What I’ve done:
Created a New Gateway using the EUI from the logs of the TTOG
created a LNS key, and converted it to a key file and uploaded that key file to the “key” field in the TTOG interface
Uploaded the Trust Certicate File
Left the Cert File Empty (what file is this?)
Configured the Rest of the Connection per the screenshot below
The TTOG remains “disconnected” in the Console.
This is the Logs from the TTOG:
2021-07-02 03:59:32.123 [SYS:INFO] Logging : /tmp/station.log (maxsize=10000000, rotate=3)
2021-07-02 03:59:32.123 [SYS:INFO] Station Ver : 2.0.3(brwodu/debugn) 2020-02-07 03:02:29
2021-07-02 03:59:32.123 [SYS:INFO] Package Ver : 1.0.0
2021-07-02 03:59:32.123 [SYS:INFO] proto EUI : 0:8002:9ccb:96b4 (/sys/class/net/eth0/address)
2021-07-02 03:59:32.123 [SYS:INFO] prefix EUI : ::1 (builtin)
2021-07-02 03:59:32.123 [SYS:INFO] Station EUI : 8002:9cff:fecb:96b4
2021-07-02 03:59:32.123 [SYS:INFO] Station home: /opt/basicstation/ (--home)
2021-07-02 03:59:32.123 [SYS:INFO] Station temp: /var/tmp/ (builtin)
2021-07-02 03:59:32.123 [SYS:INFO] GPS device: /dev/ttyS3
2021-07-02 03:59:32.123 [SYS:WARN] Station in NO-CUPS mode
2021-07-02 03:59:32.125 [RAL:DEBU] execvp argv[0]: </proc/self/exe>
2021-07-02 03:59:32.125 [RAL:DEBU] argv[1]: <-S>
2021-07-02 03:59:32.125 [RAL:DEBU] argv[2]: <(null)>
2021-07-02 03:59:32.128 [S00:INFO] Logging : /tmp/station.log (maxsize=10000000, rotate=3)
2021-07-02 03:59:32.128 [S00:INFO] Station Ver : 2.0.3(brwodu/debugn) 2020-02-07 03:02:29
2021-07-02 03:59:32.128 [S00:INFO] Package Ver : 1.0.0
2021-07-02 03:59:32.128 [S00:INFO] proto EUI : 0:8002:9ccb:96b4 (/sys/class/net/eth0/address)
2021-07-02 03:59:32.128 [S00:INFO] prefix EUI : ::1 (builtin)
2021-07-02 03:59:32.128 [S00:INFO] Station EUI : 8002:9cff:fecb:96b4
2021-07-02 03:59:32.128 [S00:INFO] Station home: /opt/basicstation/ (STATION_HOME)
2021-07-02 03:59:32.129 [S00:INFO] Station temp: /var/tmp/ (builtin)
2021-07-02 03:59:32.129 [S00:INFO] Station slave: 0
2021-07-02 03:59:32.129 [S00:WARN] Station in NO-CUPS mode
2021-07-02 03:59:32.129 [S00:INFO] Slave LGW (0) - started.
2021-07-02 03:59:32.124 [RAL:INFO] Master has started slave: pid=3377 idx=0 (attempt 1)
2021-07-02 03:59:32.329 [TCE:INFO] Starting TC engine
2021-07-02 03:59:32.331 [any:INFO] cert. version : 3
serial number : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00
issuer name : C=US, O=Internet Security Research Group, CN=ISRG Root X1
subject name : C=US, O=Internet Security Research Group, CN=ISRG Root X1
issued on : 2015-06-04 11:04:38
expires on : 2035-06-04 11:04:38
signed using : RSA with SHA-256
RSA key size : 4096 bits
basic constraints : CA=true
key usage : Key Cert Sign, CRL Sign
2021-07-02 03:59:32.331 [AIO:INFO] tc has no cert configured - running server auth and client auth with token
2021-07-02 03:59:32.439 [TCE:INFO] Connecting to INFOS: wss://lns.au.thethings.network:443
2021-07-02 03:59:33.005 [TCE:INFO] Infos: 8002:9cff:fecb:96b4 muxs-::0 wss://lns.au.thethings.network:443/traffic/eui-80029CFFFECB96B4
2021-07-02 03:59:33.005 [AIO:DEBU] [7] ws_close reason=1000
2021-07-02 03:59:33.005 [AIO:ERRO] Recv failed: SSL - The peer notified us that the connection is going to be closed
2021-07-02 03:59:33.005 [AIO:DEBU] [7] WS connection shutdown...
2021-07-02 03:59:33.006 [any:INFO] cert. version : 3
2021-07-02 03:59:33.006 [AIO:INFO] tc has no cert configured - running server auth and client auth with token
2021-07-02 03:59:33.110 [TCE:VERB] Connecting to MUXS...
2021-07-02 03:59:33.672 [S00:WARN] Ignoring unsupported/unknown field: antenna_gain
2021-07-02 03:59:33.676 [S00:INFO] Lora gateway library version: Version: 5.0.1;
2021-07-02 03:59:33.676 [S00:DEBU] SX1301 txlut table (0 entries)
2021-07-02 03:59:33.676 [S00:VERB] SX1301 rxrfchain 0: enable=1 freq=917200000 rssi_offset=-166.000000 type=2 tx_enable=1 tx_notch_freq=0
2021-07-02 03:59:33.677 [S00:VERB] SX1301 rxrfchain 1: enable=1 freq=917900000 rssi_offset=-166.000000 type=2 tx_enable=0 tx_notch_freq=0
2021-07-02 03:59:33.677 [S00:VERB] SX1301 ifchain 0: enable=1 rf_chain=0 freq=-400000 bandwidth=0 datarate=0 sync_word=0/0
2021-07-02 03:59:33.677 [S00:VERB] SX1301 ifchain 1: enable=1 rf_chain=0 freq=-200000 bandwidth=0 datarate=0 sync_word=0/0
2021-07-02 03:59:33.677 [S00:VERB] SX1301 ifchain 2: enable=1 rf_chain=0 freq=0 bandwidth=0 datarate=0 sync_word=0/0
2021-07-02 03:59:33.677 [S00:VERB] SX1301 ifchain 3: enable=1 rf_chain=0 freq=200000 bandwidth=0 datarate=0 sync_word=0/0
2021-07-02 03:59:33.677 [S00:VERB] SX1301 ifchain 4: enable=1 rf_chain=1 freq=-300000 bandwidth=0 datarate=0 sync_word=0/0
2021-07-02 03:59:33.677 [S00:VERB] SX1301 ifchain 5: enable=1 rf_chain=1 freq=-100000 bandwidth=0 datarate=0 sync_word=0/0
2021-07-02 03:59:33.677 [S00:VERB] SX1301 ifchain 6: enable=1 rf_chain=1 freq=100000 bandwidth=0 datarate=0 sync_word=0/0
2021-07-02 03:59:33.677 [S00:VERB] SX1301 ifchain 7: enable=1 rf_chain=1 freq=300000 bandwidth=0 datarate=0 sync_word=0/0
2021-07-02 03:59:33.677 [S00:VERB] SX1301 ifchain 8: enable=1 rf_chain=0 freq=300000 bandwidth=1 datarate=4 sync_word=0/0
2021-07-02 03:59:33.677 [S00:VERB] SX1301 ifchain 9: enable=0 rf_chain=0 freq=0 bandwidth=0 datarate=0 sync_word=0/0
2021-07-02 03:59:33.677 [S00:VERB] SX1301 LBT not enabled
2021-07-02 03:59:33.677 [S00:INFO] Station device: /dev/spidev0.0 (PPS capture enabled)
2021-07-02 03:59:33.579 [TCE:VERB] Connected to MUXS.
2021-07-02 03:59:33.620 [RAL:INFO] Region plan hwspec 'sx1301/1' mapped to 1 slaves 'sx1301/1'
2021-07-02 03:59:33.620 [RAL:INFO] Master sending 768 bytes of JSON sx1301conf to slave (0)
2021-07-02 03:59:33.626 [S2E:INFO] Configuring for region: AU915 -- 915.0MHz..928.0MHz
2021-07-02 03:59:33.627 [S2E:VERB] DR0 SF12/BW125
2021-07-02 03:59:33.627 [S2E:VERB] DR1 SF11/BW125
2021-07-02 03:59:33.627 [S2E:VERB] DR2 SF10/BW125
2021-07-02 03:59:33.627 [S2E:VERB] DR3 SF9/BW125
2021-07-02 03:59:33.627 [S2E:VERB] DR4 SF8/BW125
2021-07-02 03:59:33.627 [S2E:VERB] DR5 SF7/BW125
2021-07-02 03:59:33.627 [S2E:VERB] DR6 SF8/BW500
2021-07-02 03:59:33.627 [S2E:VERB] DR7 FSK
2021-07-02 03:59:33.627 [S2E:VERB] DR8 SF12/BW500
2021-07-02 03:59:33.627 [S2E:VERB] DR9 SF11/BW500
2021-07-02 03:59:33.627 [S2E:VERB] DR10 SF10/BW500
2021-07-02 03:59:33.627 [S2E:VERB] DR11 SF9/BW500
2021-07-02 03:59:33.627 [S2E:VERB] DR12 SF8/BW500
2021-07-02 03:59:33.627 [S2E:VERB] DR13 SF7/BW500
2021-07-02 03:59:33.627 [S2E:VERB] DR14 FSK
2021-07-02 03:59:33.627 [S2E:VERB] DR15 FSK
2021-07-02 03:59:33.627 [S2E:VERB] TX power: 14.0 dBm EIRP
2021-07-02 03:59:33.627 [S2E:VERB] JoinEui list: 0 entries
2021-07-02 03:59:33.627 [S2E:VERB] NetID filter: FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF
2021-07-02 03:59:33.627 [S2E:VERB] Dev/test settings: nocca=1 nodc=1 nodwell=1
2021-07-02 03:59:40.838 [SYN:INFO] First PPS pulse acquired
2021-07-02 03:59:40.838 [SYN:INFO] Obtained initial PPS offset (859570) - starting timesync with LNS
2021-07-02 03:59:40.839 [SYN:DEBU] Timesync #2 sent to server
2021-07-02 03:59:40.910 [SYN:DEBU] Timesync #3 sent to server
2021-07-02 03:59:40.981 [SYN:DEBU] Timesync #4 sent to server
2021-07-02 03:59:41.052 [SYN:DEBU] Timesync #5 sent to server
2021-07-02 03:59:41.123 [SYN:DEBU] Timesync #6 sent to server
2021-07-02 03:59:41.194 [SYN:DEBU] Timesync #7 sent to server
2021-07-02 03:59:41.265 [SYN:DEBU] Timesync #8 sent to server
You got to change the URL of the server. Refer to the screenshot above.
For Trust
certificate, download the PEM file from here .
Delete the default certificate already uploaded. Leave the CRT to blank.
For LNS Key, generate an API key from TTN V3 Console and generate a key as per the instructions mentioned here .
You’ve managed to connect to the V2 LNS successfully there…
For Version 3 - au1.cloud.thethings.network Port - 8887
No. I am able to see the gateway connected in V3 console.
In response to the other users question. Glad to hear yours is running on V3! Awesome.
Fishwaldo
(Fishwaldo)
July 2, 2021, 12:33pm
12
Ok - I see it now, but when turning on verbose mode, I see the following error:
Can that be ignored? (I’m based in Singapore)
Is the gateway forwarding traffic okay now? I’m not sure on that one - maybe someone with knowledge of that frequency plan can comment?
rikietje
(Rikietje)
July 2, 2021, 3:54pm
14
Whats the advantage of this firmware over opdk-1.01.23 that I’m running now?
(Just curious just got my TTOG 2 days ago, still testing if we are going to deploy it in production)
AcmeThings
(Acme Things)
February 11, 2025, 10:29am
15
the link is not active anymore. Is there an official website with new firmware for the TTOG that supports BasicStation?
Jeff-UK
(Jeff Uk)
February 11, 2025, 10:35am
16
Check out Things Industries support page…think there is an active firmware update link in troubleshooting section IIRC. Client used before Xmas so hope its still good…
AcmeThings
(Acme Things)
February 11, 2025, 11:52am
17
Hi @Jeff-UK , that one is working (firmware version opdk-1.01.27) but only supports the Semtech UDP forwarder, not BasicStation… The firmware mentioned earlier in this topic seems to also support CUPS and LNS.
My gateway is now working with the Semtech connection.
(had to use eu1.cloud.thethings.network instead of the address listed in the TTOG support page, which is router.eu.thethings.network)
Jeff-UK
(Jeff Uk)
February 11, 2025, 12:11pm
18
That was the LNS address for the old V2 implementation of the TTN LNS, reflecting the age of the documentation and original GW launch!
That is the current EU cluster for TTN V3, these days refered to as TTS Sandbox LNS, V2 sunset in Dec 2020.
Don’t use TTOG’s myself - my sample test unit never arrived (Covid disruption?!) (as mentioned a client had a unit lying around from Covid times that hadnt been used and decided to update before test deployment late last year… didn’t know if on UDP or BS PF.
Linking in Al Bennet from SS/Connected Things for broken link and perhaps update on current (have you looked at the SS/CT support pages for this unit?)
@eggfriedrice Hi Al good to see you at the Expo again last week - can you assist here? Note ref to (very!) old broken link…
The link I gave you earlier, per the TTI docs has link to server addresses to use:
https://www.thethingsindustries.com/docs/concepts/server-addresses/
(LNS, CUPS etc.)
AcmeThings
(Acme Things)
February 11, 2025, 12:25pm
19
Hi @Jeff-UK , @eggfriedrice I just found out Connected Things also has an office in the Netherlands (where I’m from) and was about to give them a call. I cannot find a support page on the web site
descartes
(Nick McCloud)
February 11, 2025, 1:07pm
20
Mostly the manufacturers provide the support - any distributor would be hard pressed to keep up with the changes in docs from all the products they sell.
But I know they do provide guidance & support for customers:
AcmeThings
(Acme Things)
February 11, 2025, 4:50pm
21
Hi @descartes , I sent them an email and received an answer with a link. It however seems to be a one-way: once you load the new firmware you cannot go back to the old one, and the new does not support Semtech/UDP
