TTNv3 MQTT Mosquitto and AppKey
I’m migrated from v2 to v3.
Now I follow quick start on MQTT:
https://www.thethingsnetwork.org/docs/applications/mqtt/quick-start/index.html
It wants me to replace AppKey with my Access Key (base64).
As far as I know (and can see) there is no AppKey created when I created the application.
Tried the AppKey of my device, but that is not working.
What am I missing?
Thnx!
Found it, need to use tenant (@ttn) in username and MQTT api key as password
I see the App Key but not the access key in the console
Go in to the MQTT Integration …
Dear descarts, thank you for the response. I use the “the things stack” be in the MQTT integration but there is only a
1.) Public address
2.) Public TLS address
3) Username
4) password
but no acces key…
Password = Access Key
It does say key twice on that line.
Probably help to read the docs?
https://www.thethingsindustries.com/docs/integrations/mqtt/
thanks for these importent information!
I have look for access_key with “ttn-account.” with first letters.
Only the password as access key will not work…
import time
import ttn
app_id = "foo"
access_key = "ttn-account.eiPq8mEeYRL_PNBZsOpPy-O3ABJXYWulODmQGR5PZzg"
You got that access key from v2.
But you need a Password / API key from v3 to access v3.
Read the documentation - it explains in detail how to do these things - I didn’t find the right section and copy & paste it over for my own personal pleasure.
