Your decoder function looks fine at first glance. Thank you for testing the integration! There was an issue in the initial implementation that has been fixed. Does the problem still exist? Are you sending regular updates to the integration right now? Is your channel being updated? If not please reach out to ThingSpeak at support “at” thingspeak dot com.
Have you entered the write api key for your channel and the channel ID into the integration? Can you share the data coming into your application and what it looks like when you put it through the test operation on the decoder? Sorry to create all this trouble, but Id really like to help you get it working if we can.
Not very helpful probably, but just wanted to confirm that integration “TTN to ThingSpeak” works fine for my project. Thanks for creating the integration!
Ill wait patiently kelu28. Weekends need to be doubled in size for sure.
hboictlab, thanks for the confirmation! If you can think of how we can improve the integration, please send feedback to support ‘at’ mail.thingspeak 'dot com
the Channel write API key was erased.
I do not know what happened. However, I had several times verified that I had correctly configured the integration.
I have followed the ThingSpeak-manual from TheThingsStack, which seemed pretty straight forward: just add Channel ID & API Write Key.
On ThingSpeak it displays that entries arrive but the data is empty. I guess new fields are generated whenever a get request is performed.
I have tried adding a new webhook as well as a new channel already.
