I have a problem with TTN Server and can’t find the solution so far.
Currently I use Dragino Lps8 V2 as a gateway and one week ago till now I observed there was data lost during 6 am to 8.30 am everyday.
After i did check there is problem with access the TTN, I couldn’t log in and error show as below. Anybody has the solution for it please help to advice… Thank you very much
“code”: 14,
“message”: “error:pkg/errors:net_operation ()”,
“details”: [
“namespace”: “pkg/errors”,
“name”: “net_operation”,
“message_format”: “{message}”,
“attributes”: {
“net”: “tcp”,
“op”: “dial”,
“temporary”: false,
“timeout”: false
“correlation_id”: “3a81e36f0ba54f1ba40f1bf6348d548a”,
“cause”: {
“name”: “net_dns”,
“attributes”: {
“message”: “lookup postgres on 127.0.0.11:53: no such host”,
“not_found”: true,
“temporary”: false,
“timeout”: false
“correlation_id”: “a5de5654bdbc42408d50124042aad1ae”,
“code”: 14
“code”: 14
