TTN server connection problem using Basicstation
Hi , i am trying to connect my gateway to TTN using basicstation. I created necessery files(cups.key lns.key reset_lgw.sh rinit.sh station station.conf tc.trust tc.uri). apart from that is there any files that i need and i don’t create ?
i created .key files and .trust file by ttn guide.
my station.conf file is this way
station.conf
/* If slave-X.conf present this acts as default settings /
“SX1301_conf”: { /
Actual channel plan is controlled by server /
“lorawan_public”: true, /
is default /
“clksrc”: 1, /
radio_1 provides clock to concentrator /
path to the SPI device, un-comment if not specified on the command line e.g., RADIODEV=/dev/spidev0.0 /
“device”: “/dev/spidev0.1”,
freq/enable provided by LNS - only HW specific settings listed here /
“radio_0”: {
“type”: “SX1257”,
“rssi_offset”: -166.0,
“tx_enable”: true,
“antenna_gain”: 0
“station_conf”: {
“log_file”: “stderr”, /
“station.log” /
“log_level”: “DEBUG”, /
XDEBUG,DEBUG,VERBOSE,INFO,NOTICE,WARNING,ERROR,CRITICAL /
“log_size”: 10000000,
“log_rotate”: 3,
“CUPS_RESYNC_INTV”: “1s”,
“device”: “/dev/spidev0.1”,*/
“radio_init”: “rinit.sh”,
“RADIO_INIT_WAIT”: “2s”,
“RX_POLL_INTV”: “10ms”,
“TC_TIMEOUT”: “360s”
tc.uri file contains wss://eu1.cloud.thethings.network:443
I coppied all files to my device and i run .station and i faced screen below
basic
How could i fix this and connect my gateway to TTN server ?
Please do not double post, we are all volunteers here and it splits efforts if people start answering in different threads.
It may be that you have to wait a couple of days for someone with the right knowledge to read the forum and respond.
