The data are sent correctly. My question is quite simple : how do you interpret the payload received in TTN ? In other words, how can you know the coordinates when you have a payload like : 01 88 07 B2 C1 00 9A 6A 00 1F A4 02 02 D2 60 03 67 00 BE ?
The payload you have pasted is too short. It should be at least 21 bytes (42 hex characters) long. Maybe you did not configure the the Sodaq with the correct keys?
If the payload you show was taken from TTN Console, then the keys are okay.
If the payload you show was taken from the Application Data or Device Data in TTN Console, then at least the NwkSKey is okay, and the Message Integrity Code was fine as well, for otherwise TTN would not be able to find your application to start with. The AppSKey might still be wrong, but a wrong key would not change the length of the application payload that TTN Console displays.
Still then, the 19 bytes payload you show do not match the specifications you linked to.
With our Junior IOT Challenge we have used a similar format, and the decoder function to read back the values is listed in line 60 and further in our code. You will need to adjust to your values.
@arjanvanb yes that’s what I don’t understand cause I use exactly the same code as in the link I gave. @marcovanschagen and do you remember how long your payload was ? Because it seems weird I don’t have at least 21 bytes
For your informations, I have solved the problem . Actually, in the code I defined the Cayenne format which has a shorter payload. The 2 solutions were :
1)Define the Cayenne LPP payload format in the ttn console
OR
2)Don’t transmit the payload with Cayenne. Doing so, I have a 21 bytes payload
