We have two TTN Outdoor Gateways that have recently stopped sending data. They show as connected but get no data through. When we investigate the logson both devices the same received pkt log is recorded repeatedly.
Log snippet below. Any ideas appreciated.
INFO: Received pkt from mote: 11000003 (fcnt=9925)
JSON up: {"rxpk":[{"tmst":2747296972,"time":"2021-02-08T14:20:11.486143Z","tmms":1296829211486,"chan":7,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":0.8,"lsnr_min":-5.8,"lsnr_max":3.5,"rssi":-121,"size":23,"data"
:"AAMAABECxSYsyEQQ0KTVs3AJxkovtoE="}]}
INFO: [up] PUSH_ACK received in 11 ms
JSON up: {"rxpk":[{"tmst":2747329284,"time":"2021-02-08T14:20:11.518455Z","tmms":1296829211518,"chan":6,"rfch":1,"freq":868.300000,"stat":1,"modu":"LORA","datr":"SF8BW125","codr":"4/5","lsnr":-4.0,"lsnr_min":-5.8,"lsnr_max":1.5,"rssi":-113,"size":23,"data
":"AAMAABECxSYsZj8Q0KTVs3C8dUr4jNY="}]}
JSON up: {"rxpk":[{"tmst":2747387732,"time":"2021-02-08T14:20:11.576903Z","tmms":1296829211576,"chan":6,"rfch":1,"freq":868.300000,"stat":1,"modu":"LORA","datr":"SF10BW125","codr":"4/5","lsnr":-4.8,"lsnr_min":-7.0,"lsnr_max":-0.2,"rssi":-114,"size":23,"da
ta":"AAMAABECxSYsbUMQ0KTVs3BWIJBFG4Y="}]}
