TTN Mapper is not drawing The Things Stack CE devices on map
A while ago, my transmitter was using the legacy TTN v2 network together with TTN mapper integration. On the map, TTN mapper draws the gateway coverage of that one single transmitter quite well. The transmitter was located in the centre point of this map:
Now I have upgrade the transmitter to use The Things Stack CE and enabled its TTN mapper integration. The transmitter is located in Dublin and four gateways consistently pick up its transmissions. However, TTN mapper no longer draws the gateway coverage in the vicinity of the transmitter, evident from the complete absence of radial lines drawn in the Dublin city area:
Is there a technical limitation in The Things Network CE that prevents TTN mapper from plotting gateways’ coverage on a map?
Did you read this? JP is working hard on it.
That’s great to know!
