Today I had to use ttn-lw-cli to change a configuration that is not available on the console. I ran into a couple of issues, which I had to solve to get it to work. I’m using Ubuntu 20.04. Here are my workarounds.
The TTI docs recommend one to use the snap package on Linux. I’ve tried and tried, but could not get the config file path and permissions to work. Luckily I found there is a deb package available on github.
- Remove snap:
$ snap remove ttn-lw-stack
- Download deb from Releases · TheThingsNetwork/lorawan-stack · GitHub. In my case I used
lorawan-stack_3.14.1_linux_amd64.deb
. - Install deb:
$ sudo apt install ./lorawan-stack_3.14.1_linux_amd64.deb
- Create a config file:
$ ttn-lw-cli use eu1.cloud.thethings.network
At this point you can view the content of the config file by doing $ cat ~/.ttn-lw-cli.yml
. A sharp eye will see that the identity server address is incorrect: identity-server-grpc-address: eu1.cloud.thethings.industries:8884
This will cause commands like $ ttn-lw-cli applications list
to fail with an error error:pkg/tenant/middleware:missing_tenant_id (missing tenant ID)
To fix this we need to edit the config file, using a command like $ nano ~/.ttn-lw-cli.yml
and replace:
with identity-server-grpc-address: eu1.cloud.thethings.network:8884
Now doing a command like $ ttn-lw-cli applications list
will succeed without an error.
These two issues were reported to TTI.
