Clearly the javascript payload decoder does not support the javascript error handling as try{}, catch{} and finally{}. Any idea about alternatives?
Works for me:
var error;
try {
console.log("Here we go!");
// should throw: 'myvar' is not defined
console.log(myvar);
catch (e) {
console.log(e);
error = e;
finally {
if (error) {
return {worksForMe: error};
return {oops: "exception not caught"};
This shows:
When not using try-catch then see also the MQTT error events as mentioned in Is there any documentation on payload functions?
Thanks Arjan. Solved:
catch {} as empty was not accepted (My excuse: Firefox JS scratchbook did accept it however and did not complain).
Solution is simple: do not use catch as empty statement.
Probably not important at all, but for future reference: leaving out the identifier (e) (or whatever name is used like, like (error)) from catch (e) is indeed invalid. But an empty statement work just fine as well:
try {
console.log(myvar);
console.log("Oops, we should not get here");
catch (e) {
finally {
return {worksForMe: "yes"};
return {oops: "finally not executed"};
Same results without any catch at all; at least one of catch or finally must be present.
