Hi ,
How do I set up the TTN 915 GW so the data just goes to my local network in stead of going to the TTN?
(ie packet forward)
Regs
Joe
Hi ,
(ie packet forward)
Regs
Joe
you want a ‘private backend’ I think
its not possible to get decoded packets from your gateway direct to your LAN
The TTN Gateways with regular software builds do not support forwarding packets to a local network server. Only connections to TTN are supported. If you want to use a local connect back-end you will need to change the software and create your own build.
Thanks from down under
