Hello!
I have The Things Gateway activated with TTN which I am able to see on console up and running. Also I have Lopy Lora Micro python board. I have a question can I add Lopy as node to TTN gateway.
Thank you
did you try ?
you donât âaddâ nodes to a gateway⌠you register and add them to an application.
I created application and added Lopy but status for device showing ânever seenâ,
thatâs really not enough info.
https://www.thethingsnetwork.org/docs/devices/lopy/
https://docs.pycom.io/chapter/gettingstarted/
https://docs.pycom.io/chapter/gettingstarted/registration/lora/ttn.html
https://www.thethingsnetwork.org/forum/search?q=lopy
Thank you.
I have some progress TTN gateway is up and running, but I am stuck now with scenario.
https://docs.pycom.io/chapter/tutorials/lora/lorawan-otaa.html
I am trying to connect over the air to my TTN Gateway which is up and running from Lopy
and keep getting the message: âNot yet joinedâŚâ
any ideas
update: I was able to get connection only using ABP method
Still unclear how to register Lopy with US915 TTN gateway via OTAA method.
Does anybody have registered?
I was able to get register Loy with TTN US915
youâve found it⌠great !
maybe you want to share how for other users ?
My post on the Pycom might help Pycom fipy connects ok with ABP but not OTAA
Hi
I used Pycom Lopy with latest firmware. TTN gateway with original firmware.
code as per below
from network import LoRa
import socket
import time
import struct
import binascii
lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.US915)
dev_eui = binascii.unhexlify(âxxxxâ)
app_eui = binascii.unhexlify(âxxxxâ)
app_key = binascii.unhexlify(âxxxxâ)
for channel in range(0, 72):
lora.add_channel(channel, frequency=903900000, dr_min=0, dr_max=3)
join a network using OTAA
lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0, dr=4)
wait until the module has joined the network
join_wait = 0
while True:
time.sleep(2.5)
if not lora.has_joined():
print(âNot joined yetâŚâ)
join_wait += 1
if join_wait == 5:
lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0, dr=0)
join_wait = 0
else:
break
create a LoRa socket
s = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
set the LoRaWAN data rate
s.setsockopt(socket.SOL_LORA, socket.SO_DR, 0)
make the socket blocking
s.setblocking(False)
time.sleep(5.0)
for i in range (200):
pkt = bâPKT #â + bytes([i])
print(âSending:â, pkt)
s.send(pkt)
time.sleep(4)
rx, port = s.recvfrom(256)
if rx:
print(âReceived: {}, on port: {}â.format(rx, port))
time.sleep(6)
