TTN Device not received message
Hi All;
I would like to know why my TTN gateway received message but my device not received message.
1234
my gateway
4312
my device data
Thank you
Best regards.
Hi @empirejrz. Which router is your gateway connected to and which handler is your application connected to?
Might be the same issue as Thethings.meshed.com.au Vs thethingsnetwork.org
I use RAK831 for gateway to upload to TTN and I setup application on TTN.
1
2
Thank you,
Best regards.
http://noc.thethingsnetwork.org:8085/api/v2/gateways/eui-b827ebfffeaaf951
you show here 2 different accounts… ?
PanuponB-empirejrz
  • na waarschuwing bewust doorgaan met de groeten doen in iedere post
Port 0 is for network traffic and can not be used for application data.
@BoRRoZ I delete my account and create new account. I would like to know why TTN not acknowledge frist frame. I understanding when first time my End-Node send information to Network server and Network server send acknowledge to End-Node then my End-Node send information such as temperature, Humidity, etc follow by Cayenne format to Network server.
Thank you,
Best regards.
