TTN connection to Azure lost when changing Azure DB password
Hi all,
At the risk of asking something too obvious:
  • we’ve been running TTN connected devices for over a year now with no issues after going to LMIC-node as the SW base for our devices
  • up until Jul 30 all data was dutyfully sent on to Azure
  • then for unrelated reasons I needed to change the PW of the Azure DB and the uploads from TTN stopped, although nothing on the TTN side changed
  • Changing the Azure DB back solved the issue
My question is this: does anybody know where else I need to update the Azure DB password apart from Azure itself? It must be set somewhere in TTN apparently (I thought access was arranged through the app keys) but for the life of me I can’t find it.
Maybe I’m blind, but I’d be grateful if someone can point it out.
Rebuilding the Azure integration (remove old integration, make a new one) didn’t solve it.
Best,
TUJP
